Ana içeriğe geç
How To Re-String A Hoodie
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
  1. How To Re-String A Hoodie, How To Re-String A Hoodie: adım 1, 2 resimden 1. How To Re-String A Hoodie, How To Re-String A Hoodie: adım 1, 2 resimden 2.
    • Uncoil the wire coat hanger into a straight line.
  2. How To Re-String A Hoodie: adım 2, 3 resimden 1. How To Re-String A Hoodie: adım 2, 3 resimden 2. How To Re-String A Hoodie: adım 2, 3 resimden 3.
    • Tape the end of the uncoiled coat hanger to one end of your sweatshirt string.
    • Make sure the clothes hanger is securely taped to ensure that the string doesn't detach during the re-stringing process.
    • When taping, make sure no adhesive is felt over the outside of the apparatus. This will make the re-stringing process easier because the tape won't be sticking to the sweatshirt.
  3. How To Re-String A Hoodie: adım 3, 1 resimden 1.
    • Insert the wire and string apparatus into the left opening of the hoodie.
  4. How To Re-String A Hoodie: adım 4, 1 resimden 1.
    • Feed the wire through the hoodie until it reaches the top of the hood.
  5. How To Re-String A Hoodie: adım 5, 2 resimden 1. How To Re-String A Hoodie: adım 5, 2 resimden 2.
    • Curve the wire to the right so that the wire can follow the curve of the hood.
  6. How To Re-String A Hoodie: adım 6, 2 resimden 1. How To Re-String A Hoodie: adım 6, 2 resimden 2.
    • Continue feeding the wire through the hood towards the other opening of the hoodie.
    • Pull the wire and string out of the opening.
  7. How To Re-String A Hoodie: adım 7, 2 resimden 1. How To Re-String A Hoodie: adım 7, 2 resimden 2.
    • Remove the tape from the end of the wire and string.
  8. How To Re-String A Hoodie: adım 8, 2 resimden 1. How To Re-String A Hoodie: adım 8, 2 resimden 2.
    • Remove the wire from the hoodie by pushing the left end of the wire through the hoodie, while pulling the right end out.
  9. How To Re-String A Hoodie: adım 9, 1 resimden 1.
    • Tie each end of the string in a knot to prevent the string from coming out of the hoodie.
Sonuç
Congratulations on restringing your hoodie!
4 farklı kişi bu kılavuzu tamamladı.
Ashley
267 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 23-1, Green Winter 2015 Cal Poly, Team 23-1, Green Winter 2015 üyesi
CPSU-GREEN-W15S23G1
4 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
my apple iphone 4 is disabled connect to itunes
Ali Hemmati - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 9
Her zaman: 268
