Giriş
This guide will walk you through removing, cleaning, lubricating, and reassembling an older model coaster brake.
Neye ihtiyacın var
Loosen the nuts holding the axle in place using the two wrenches.
Unscrew the brake arm from the frame of the bicycle using the screwdriver.
Reassemble the parts of the bearing and axle assembly which go on the opposite side of the hub from the sprocket. This includes the brake pads and the cone
Using your fingers, make sure the bearings are well coated with grease.
Make sure to add some grease at key points shown (red lines).
Congratulations! You've finished cleaning your coaster brake. Test-ride the bicycle. Listen to make sure that there are no grinding noises. Be sure to test the brake several times. When you're done, make sure all the nuts are still tight.
6 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I have Huffy coaster bike 26”, i’m trying to change the rear tire bearing but I don’t know the size of it. the outside ones are 3/16 X9, but I need to know the size of the small inner one at the gear it was 7 balls.
Can you explicitly say which order the parts go back in?
It should be easy, but I can't quite get it straight.
