Ana içeriğe geç
How To Remove Rust From Old Tools
Neye ihtiyacın var
    1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: adım 1, 2 resimden 1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: adım 1, 2 resimden 2.
      • Removing rust generally isn't dangerous, but it's pretty messy.
      • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
      • Consider also wearing protective gloves.
      • Place your tool on the towels.
      FixBot'a Sor
      Yorum Ekle
    2. How To Remove Rust From Old Tools: adım 2, 2 resimden 1. How To Remove Rust From Old Tools: adım 2, 2 resimden 2.
      • Spray the rusty areas of the tool with a generous amount of WD-40.
      FixBot'a Sor
      Yorum Ekle
    3. How To Remove Rust From Old Tools: adım 3, 3 resimden 1. How To Remove Rust From Old Tools: adım 3, 3 resimden 2. How To Remove Rust From Old Tools: adım 3, 3 resimden 3.
      • Use a scouring pad to thoroughly scrub the tool.
      • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
      FixBot'a Sor
      Yorum Ekle
    4. How To Remove Rust From Old Tools: adım 4, 3 resimden 1. How To Remove Rust From Old Tools: adım 4, 3 resimden 2. How To Remove Rust From Old Tools: adım 4, 3 resimden 3.
      • Use a paper towel to wipe away the excess grime and WD-40.
      FixBot'a Sor
      Yorum Ekle
    5. How To Remove Rust From Old Tools: adım 5, 1 resimden 1.
      • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
      • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
      FixBot'a Sor
      Yorum Ekle
Sonuç
13 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
92.939 İtibar
88 adet Kılavuz yazıldı
3Kılavuz Yorumları
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Yanıt Paylaş
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Yanıt Paylaş
Coca-Cola also works, soak over night
Gil Flores - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 40
Son 30 gün: 176
Her zaman: 9,284
