Ana içeriğe geç
How To Remove Rust From Old Tools
Neye ihtiyacın var
  1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: adım 1, 2 resimden 1. How To Remove Rust From Old Tools, How To Remove Rust From Old Tools: adım 1, 2 resimden 2.
    • Removing rust generally isn't dangerous, but it's pretty messy.
    • Prepare your workspace by laying out an old towel or shop rag that you won't mind getting dirty.
    • Consider also wearing protective gloves.
    • Place your tool on the towels.
  2. How To Remove Rust From Old Tools: adım 2, 2 resimden 1. How To Remove Rust From Old Tools: adım 2, 2 resimden 2.
    • Spray the rusty areas of the tool with a generous amount of WD-40.
  3. How To Remove Rust From Old Tools: adım 3, 3 resimden 1. How To Remove Rust From Old Tools: adım 3, 3 resimden 2. How To Remove Rust From Old Tools: adım 3, 3 resimden 3.
    • Use a scouring pad to thoroughly scrub the tool.
    • It shouldn't take a lot of force—the WD-40 and scouring pad will do most of the work.
  4. How To Remove Rust From Old Tools: adım 4, 3 resimden 1. How To Remove Rust From Old Tools: adım 4, 3 resimden 2. How To Remove Rust From Old Tools: adım 4, 3 resimden 3.
    • Use a paper towel to wipe away the excess grime and WD-40.
  5. How To Remove Rust From Old Tools: adım 5, 1 resimden 1.
    • Continue scouring the tool, adding more WD-40 as needed, until the surface is free of rust.
    • When you finish, your tool may not look brand new—but the surface should now be rust-free and ready for years of continued use.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
92.044 İtibar
89 adet Kılavuz yazıldı
2Kılavuz Yorumları
Apple cider vinegar removes rust well. Try it.
Michael Jucker - Yanıt
Thank you I have tried vinagar ,rust buster and other sprays and only the WD 40 worked best
Ronald Tyler - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 24
Son 30 gün: 162
Her zaman: 7,447
