Ana içeriğe geç
How To Repair A Sticking Mountain Bike Brake Line
Neye ihtiyacın var
  1. How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: adım 1, 3 resimden 1. How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: adım 1, 3 resimden 2. How To Repair A Sticking Mountain Bike Brake Line, How To Repair A Sticking Mountain Bike Brake Line: adım 1, 3 resimden 3.
    • Remove the grip from the bike's handle bar.
    • Use short twisting motions. If the grip is really stuck onto the bar, some soapy water can help it come off easier.
  2. How To Repair A Sticking Mountain Bike Brake Line: adım 2, 2 resimden 1. How To Repair A Sticking Mountain Bike Brake Line: adım 2, 2 resimden 2.
    • Unscrew the hex screw on the brake fixture on the handle bars with the allen wrench.
    • Once the brake fixture is loose, pull off the fixture form the handle and set aside.
  3. How To Repair A Sticking Mountain Bike Brake Line: adım 3, 3 resimden 1. How To Repair A Sticking Mountain Bike Brake Line: adım 3, 3 resimden 2. How To Repair A Sticking Mountain Bike Brake Line: adım 3, 3 resimden 3.
    • Unhook the brake line from the bike's body by sliding the line backwards and pulling up in one motion.
    • If the brake line is too tight to pull back, you may have to remove the rear tire to let the brake pads move farther.
  4. How To Repair A Sticking Mountain Bike Brake Line: adım 4, 3 resimden 1. How To Repair A Sticking Mountain Bike Brake Line: adım 4, 3 resimden 2. How To Repair A Sticking Mountain Bike Brake Line: adım 4, 3 resimden 3.
    • Remove the brake line from the brake assembly you removed in step one.
    • Unscrew the adjustment screw all the way out of the assembly.
    • Push brake line forward and slide the line out of the slot in the brake handle.
    • Check the spring of the brake lever without the line connected. If it does not retract well, you can clean it with soapy water.
  5. How To Repair A Sticking Mountain Bike Brake Line: adım 5, 2 resimden 1. How To Repair A Sticking Mountain Bike Brake Line: adım 5, 2 resimden 2.
    • To remove the brake line from the rear brake pads. Unhook the line from the metal insert.
    • Unscrew the hex bolt with an allen wrench.
  6. How To Repair A Sticking Mountain Bike Brake Line: adım 6, 1 resimden 1.
    • After you have removed the bike's brake line, take the whole assembly wipe with a soapy water solution to remove rust, dirt, grease and anything else stopping the line from traveling freely.
    • After removing all of the debris, apply chain oil to another rag and wipe oil evenly onto the line.
    • Careful the line itself could be frayed anywhere due to age and be sharp.
Sonuç
Once finished, put back together the brake assembly. Then test the mobility of the brakes before riding. Happy Riding!
4 farklı kişi bu kılavuzu tamamladı.
Spencer Solano
342 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-1, Green Spring 2015 Cal Poly, Team 30-1, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G1
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
I’d like to comment just because I think it’s unnecessary to remove the brake leaver as it can be quite a troublesome job to remove and refit the grip and there is really no need to do so in this instance.
ndlz84 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 7,692
