Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Unscrew the hex screw on the brake fixture on the handle bars with the allen wrench.
Once the brake fixture is loose, pull off the fixture form the handle and set aside.
Unhook the brake line from the bike's body by sliding the line backwards and pulling up in one motion.
Remove the brake line from the brake assembly you removed in step one.
Unscrew the adjustment screw all the way out of the assembly.
Push brake line forward and slide the line out of the slot in the brake handle.
To remove the brake line from the rear brake pads. Unhook the line from the metal insert.
Unscrew the hex bolt with an allen wrench.
After you have removed the bike's brake line, take the whole assembly wipe with a soapy water solution to remove rust, dirt, grease and anything else stopping the line from traveling freely.
After removing all of the debris, apply chain oil to another rag and wipe oil evenly onto the line.
3 farklı kişi bu kılavuzu tamamladı.
