Ana içeriğe geç
How To Repair An Overheating D-LINK DIR-655 Wireless Router
Neye ihtiyacın var
  1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 1, 2 resimden 1. How To Repair An Overheating D-LINK DIR-655 Wireless Router, How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 1, 2 resimden 2.
    • Start by removing the three antennas by twisting each one in a counter-clockwise direction when facing the back panel.
  2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 2, 2 resimden 1. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 2, 2 resimden 2.
    • Using your flathead screwdriver or plastic opening tool, gently pry the top two screw covers out of the router's case.
  3. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 3, 3 resimden 1. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 3, 3 resimden 2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 3, 3 resimden 3.
    • Using your Phillips screwdriver, turn the screw counter-clockwise to remove it from the assembly.
    • Do the same for the second screw.
  4. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 4, 1 resimden 1.
    • Gently pry the top of the case from the sides and bottom of the router.
    • After freeing the top, remove it and set it aside.
  5. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 5, 2 resimden 1. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 5, 2 resimden 2.
    • With your Phillips screwdriver, remove both screws by rotating in a counter-clockwise direction.
  6. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 6, 1 resimden 1.
    • After removing the screws, lift the white LED cover up and off of the circuit board.
  7. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 7, 3 resimden 1. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 7, 3 resimden 2. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 7, 3 resimden 3.
    • Next, bend up the clip holding down the middle antenna wire.
    • Gently, unhook the wire and move it out of the way.
  8. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 8, 1 resimden 1.
    • With the wire out of the way, separate the circuit board from the bottom assembly.
    • Be sure not to pinch or bend the antenna wire when you lift the circuit board.
  9. How To Repair An Overheating D-LINK DIR-655 Wireless Router: adım 9, 1 resimden 1.
    • Wipe away any dust from the the vents to ensure proper airflow.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Chance Daniel
263 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-6, Green Fall 2015 Cal Poly, Team 10-6, Green Fall 2015 üyesi
CPSU-GREEN-F15S10G6
3 Üyeler
3 adet Kılavuz yazıldı
1Rehber Yorum
Fixed my unit :-)
larry_wollen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 5,650
