Ana içeriğe geç
How To Replace Burners on Weber Genesis II Grill
Neye ihtiyacın var
  1. How To Replace Burners on Weber Genesis II Grill, Burners: adım 1, 3 resimden 1. How To Replace Burners on Weber Genesis II Grill, Burners: adım 1, 3 resimden 2. How To Replace Burners on Weber Genesis II Grill, Burners: adım 1, 3 resimden 3.
    • This is the Weber Genesis II grill. Before replacement of the burner, we will start by cleaning the grates with a grill brush in order to be clean and safe.
    • Make sure that the grill is completely turned off so there is no chance of accidental burn.
  2. How To Replace Burners on Weber Genesis II Grill: adım 2, 3 resimden 1. How To Replace Burners on Weber Genesis II Grill: adım 2, 3 resimden 2. How To Replace Burners on Weber Genesis II Grill: adım 2, 3 resimden 3.
    • Remove the grates using your hands.
    • Grab on each side of the grill grate with your hands and lift straight upwards.
    • Set the removed grate off to the side of the grill.
    • Repeat this procedure for all three of the grates on top of the grill.
  3. How To Replace Burners on Weber Genesis II Grill: adım 3, 3 resimden 1. How To Replace Burners on Weber Genesis II Grill: adım 3, 3 resimden 2. How To Replace Burners on Weber Genesis II Grill: adım 3, 3 resimden 3.
    • Remove the heat deflector plates from on top of the burners.
    • Grab each deflector plate and pull straight upwards as with the grates.
    • Place the removed heat deflector plates off to the side of the grill.
    • Repeat this procedure for all heat deflector plates until each burner is exposed.
    • Only half of the heat deflectors plates will have burners underneath them. So do not be alarmed when not all plates have a burner.
  4. How To Replace Burners on Weber Genesis II Grill: adım 4, 3 resimden 1. How To Replace Burners on Weber Genesis II Grill: adım 4, 3 resimden 2. How To Replace Burners on Weber Genesis II Grill: adım 4, 3 resimden 3.
    • Remove the burner from its slot in the back of the grill.
    • With both hands, carefully pull the burner upwards and slightly to the left in order to pull it out of its slot.
    • The burners can become stuck and require a little extra force to pull out, but do not pull too hard and hit the top of the grill or yourself.
    • If replacing all burners, repeat this procedure to remove all burners from their slots.
  5. How To Replace Burners on Weber Genesis II Grill: adım 5, 3 resimden 1. How To Replace Burners on Weber Genesis II Grill: adım 5, 3 resimden 2. How To Replace Burners on Weber Genesis II Grill: adım 5, 3 resimden 3.
    • Detach the burner from the ignition device.
    • With a small wedge, such as a flat-head screwdriver, unclip the white connector from the burner.
    • With the ignition device removed, you are now all set to replace the burner with a new one.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Nicholas Brown
175 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 54
Son 30 gün: 306
Her zaman: 8,804
