Ana içeriğe geç
How To Replace Ski Pole Baskets
Neye ihtiyacın var
  1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: adım 1, 2 resimden 1. How To Replace Ski Pole Baskets, How To Replace Ski Pole Baskets: adım 1, 2 resimden 2.
    • Place the sock over your hand like a glove.
    • You will be using this hand to pull off the heated basket.
  2. How To Replace Ski Pole Baskets: adım 2, 2 resimden 1. How To Replace Ski Pole Baskets: adım 2, 2 resimden 2.
    • Heat the worn/broken basket with a blow dryer to melt the existing adhesive.
    • Heat for no longer then three minutes.
  3. How To Replace Ski Pole Baskets: adım 3, 2 resimden 1. How To Replace Ski Pole Baskets: adım 3, 2 resimden 2.
    • Use your protected hand to pull firmly on the basket until it comes off of the pole once it is heated.
  4. How To Replace Ski Pole Baskets: adım 4, 2 resimden 1. How To Replace Ski Pole Baskets: adım 4, 2 resimden 2.
    • Heat an all purpose glue stick with a lighter.
  5. How To Replace Ski Pole Baskets: adım 5, 2 resimden 1. How To Replace Ski Pole Baskets: adım 5, 2 resimden 2.
    • Spread a very thin layer of the melted glue on the basket end of the pole, then press on the new basket.
    • Press the new basket immediately after applying the melted glue in order to obtain maximum adhesion.
  6. How To Replace Ski Pole Baskets: adım 6, 1 resimden 1.
    • Reheat the replaced basket with a hair dryer for a minute.
    • After heating, allow the glue to cool and set for 10 minutes.
  7. How To Replace Ski Pole Baskets: adım 7, 1 resimden 1.
    • After drying for 10 minutes, your poles will be ready for use. Happy Skiing!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lia Garkie
131 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G3
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 63
Her zaman: 17,635
