Giriş
This guide shows you how to replace the water inlet valve in your washing machine when it no longer starts, fails to fill, or continuously leaks water. Replacing this valve can restore normal water flow and fix issues with filling or flooding. Always check your manufacturer’s guidelines and be aware that any unauthorized repair could affect your warranty.
Neye ihtiyacın var
Adım 2 Access the inlet valve area
Locate and remove the retaining screws or clips securing the top panel of the machine.
Lift or slide the top panel to expose the inlet valve assembly at the back.
Adım 3 Detach the old valve
Loosen and remove any screws or brackets holding the inlet valve in place.
Slide off any wire connectors from the old valve.
Adım 4 Disconnect water hoses
Place a container or cloth beneath the internal hoses to catch spilling water.
Loosen and remove the hose clamps or clips from the valve’s outlet ports.
Adım 5 Match compartments and orifices
Confirm the softener port has the correct internal nozzle or insert as required.
Adım 6 Install the new valve
Attach each hose to the corresponding port on the replacement valve and secure the hose clamps.
Reinstall the valve in its original position and secure it with screws or brackets.
Reconnect the wire connectors in the same order you noted before.
Adım 7 Perform a short test
Select a short wash or pre-wash cycle to check for correct water flow and leaks.
Turn the dial to the main wash and softener programs to verify proper flow in each compartment.
Adım 8 Replace cover and finalize
Shut off the power once more and reinstall the machine’s top panel securely.
Plug in your washer, turn on the water supply, and run a full wash cycle to confirm normal operation.
Replacing the inlet valve restores proper water flow to your washing machine and can resolve filling or leaking problems. Remember to follow all safety guidelines, and consult the manufacturer’s instructions to ensure compliance with any warranty conditions. If uncertain, contact a qualified service technician.
