Giriş
The life of a trash can is dirty and rough. With those conditions, it can be expected that something will eventually break. Here is our guide to replacing the wheels of a 96 gallon toter trash can in the case that it does break. No experience is necessary, only a couple tools and these steps will get you a trash can that can roll again.
Neye ihtiyacın var
Now that your trash can is up and rolling again, you can now pat yourself on the back for a job well done!
Bir başkası bu kılavuzu tamamladı.
6Kılavuz Yorumları
What size pal nuts on trash barrels
Putting wheels back on trash barrel.Need to replace pal nut and would like to know if there is a standard size to purchase
Hi there!
Upon looking at this specific replacement kit, the Pal-Nut size they used is 5/8”. Since you may have a different trash can with a different size axle, you should refer to any replacement kits made online and see what size Pal-Nut they use.
I am a 65 year grandmother and I replaced the wheels on my 20 year Toter with no issues, Found the repacement parts online. Proud of myself
