Giriş
The life of a trash can is dirty and rough. With those conditions, it can be expected that something will eventually break. Here is our guide to replacing the wheels of a 96 gallon toter trash can in the case that it does break. No experience is necessary, only a couple tools and these steps will get you a trash can that can roll again.
Neye ihtiyacın var
Position the flathead screwdriver on the tab of the pal-nut in the center of the wheel.
Position the rubber mallet on top of the flathead screwdriver.
Hit the flathead screwdriver with the rubber mallet a couple times for each tab.
Now that your trash can is up and rolling again, you can now pat yourself on the back for a job well done!
Bir başkası bu kılavuzu tamamladı.
6 Yorum
What size pal nuts on trash barrels
Putting wheels back on trash barrel.Need to replace pal nut and would like to know if there is a standard size to purchase
Hi there!
Upon looking at this specific replacement kit, the Pal-Nut size they used is 5/8”. Since you may have a different trash can with a different size axle, you should refer to any replacement kits made online and see what size Pal-Nut they use.
I am a 65 year grandmother and I replaced the wheels on my 20 year Toter with no issues, Found the repacement parts online. Proud of myself
It has a solid plastic outside and no nut
Judy Spaul - Yanıt
