Ana içeriğe geç
How To Reset a Suitcase Lock
    1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: adım 1, 2 resimden 1. How To Reset a Suitcase Lock, How To Reset a Suitcase Lock: adım 1, 2 resimden 2.
      • Set the suitcase down with the combination lock facing up.
      FixBot'a Sor
      Yorum Ekle
    2. How To Reset a Suitcase Lock: adım 2, 1 resimden 1.
      • Turn a flashlight towards the lock, so that you can see the small details.
      FixBot'a Sor
      Yorum Ekle
    3. How To Reset a Suitcase Lock: adım 3, 3 resimden 1. How To Reset a Suitcase Lock: adım 3, 3 resimden 2. How To Reset a Suitcase Lock: adım 3, 3 resimden 3.
      • Rotate the three gears together so that the grooved part of each gear faces the outside.
      • Correct: Gear faces the outside.
      • Gear faces the inside.
      FixBot'a Sor
      Yorum Ekle
    4. How To Reset a Suitcase Lock: adım 4, 1 resimden 1.
      • Remember the number of the three gears when the groove part is on the outside.
      • As of now the code number of the three gears is 181.
      FixBot'a Sor
      Yorum Ekle
    5. How To Reset a Suitcase Lock: adım 5, 1 resimden 1.
      • Add 5 to each of the three numbers. For example, my numbers are 181. After adding 5, the code to my lock would be 636.
      • Turn the numbers on the lock to 636, and then unlock the lock.
      FixBot'a Sor
      Yorum Ekle
    6. How To Reset a Suitcase Lock: adım 6, 2 resimden 1. How To Reset a Suitcase Lock: adım 6, 2 resimden 2.
      • Sometimes the difference is not 5 from the grooved spots. In this case, you can try to increase the numbers after adding 5.
      • For example, if 636 does not work, try to add 6 to the three numbers. Then the code is 747 and attempt to unlock the lock. Continue to add 7, then 8 to try, until it can be opened.
      FixBot'a Sor
      Yorum Ekle
    7. How To Reset a Suitcase Lock: adım 7, 2 resimden 1. How To Reset a Suitcase Lock: adım 7, 2 resimden 2.
      • When I added 8 and my number was 969, the lock unlocked. We successfully opened the suitcase!
      FixBot'a Sor
      Yorum Ekle
Sonuç
After reading my guide, you will never encounter the problem that the suitcase cannot be opened without remembering the password. It can be solved anytime, anywhere.
6 farklı kişi bu kılavuzu tamamladı.
Lisha Li
469 İtibar
2 adet Kılavuz yazıldı
Ekip
4Kılavuz Yorumları
OMG! A big THANK YOU!!! It worked.
Edward Lee - Yanıt Paylaş
Amazing. This worked for me
Leena Daykin - Yanıt Paylaş
It worked for me too
georgeteach - Yanıt Paylaş
Surprised ! And grateful also to the author. I opened the lock with forgotten combination in just 3 minutes.
Chandrashekhar Dadhekar - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 25
Son 7 gün: 148
Son 30 gün: 684
Her zaman: 58,725
