Giriş
iOS 13 update has again brought the True Tone missing problem to some iPhone users. Well, some people have worked out a new solution to fix the problem. We will take iPhone XS as an example and show you how to restore True Tone of aftermarket screens step by step.
Neye ihtiyacın var
Videoya Genel Bakış
Go to Settings>General>About and check the software version of the phone – iOS 13.2. Tap Display & Brightness. We can see that the True Tone has been turned on with the switch being green.
Replace with a new aftermarket screen.
Tap Display & Brightness. We can see that the true tone option has vanished.
Now, let’s restore the true tone with the multi-functional programmer.
First, connect the display extended module with the programmer. Next, connect the original screen with the display extended module.
Then we need to use the programmer to read data on the original screen.
Once finished, disconnect the original screen and connect the aftermarket screen with the display extended module.
This time we use the programmer to write the data to the aftermarket screen. Once finished, disconnect the aftermarket screen.
Bonjour, quels sont les outils / Logiciels complémentaires nécessaires pour cette reprogrammation ? Merci.
Go to Settings>General>About and check the software version of the phone – iOS 13.2. Continue to tap Display & Brightness. We can see that there is no true tone option.
Connect the phone to the computer and open the WL assistance software. The cover board number of the phone has been read automatically.
Continue to power off and disconnect the phone from the computer. Remove the aftermarket screen afterwards.
Cos’è il software di assistenza WL?
Vorrei saperlo anche io,
Ho provato con 3uTools su un IPHONE 12 ma non lo riesce a leggere
Boncy -
Hakverdi Erdek
Now, let’s restore the true tone without the original screen.
Connect the aftermarket screen with the display extended module and connect the multi-functional true tone programmer to the computer.
To restore true tone without the original screen, we need to write the previously read cover board number to the aftermarket screen with the help of the software.
Now we can assemble the phone and test. Get the aftermarket screen installed and connect the battery. Press the power button to turn on the phone.
Continue to tap Display & Brightness. We can see that the True Tone has been turned on with the switch being green. The True Tone has been restored back.
What’s the name of the machine for restoring true tone
I once did it successfully using better idea‘s clone boy 2.0 with my iphone8.
the replacement screen needs to have an eeprom installed - not every aftermarket screen has one.
I used an original refurbed iPhone8 display successfully.
When the screen broke again a few months later (I have four kids - they trash everything) I again bought a refurbished iPhone Screen and copied the ID from the previous replacement to the new refurb screen. Somehow this did not made True Tone reappear after installation even though I tried it twice.
Just after glueing anything together I found my first original screen in the recycling box. Maybe it would have worked if I copied directly from it but since everything else works fine (approximation sensor e. g.) I decided to store the first screen away and leave the phone as it is.
You can get the clone boy cheap from AliExpress but I saw some other devices which are able to clone the screen ID too. A quick search on the web should reveal something helpful.
vous utilisez l’ecran d’origine pour extraire le mtsn et le copier sur l’écran de remplacement. Pourquoi dire que la procédure se fait sans l’écran d’origine? Ce n’est pas clair. Ce qui est clair, c’est que si vous ne disposez pas de l’écran d’origine, vous ne pouvez pas du tout restaurez True Tone.
26 farklı kişi bu kılavuzu tamamladı.
26 Yorum
Would this work with an original screen on another body?
Really nice fix!
I had installed an original iPhone screen from another body on my iPhoneXS . I used this tool for restoring TrueTone and it worked like a charm!
Hi is there any msg “ iphone canot check your screen”
Can anyone tell me where I you purchase the True Tone multi-functional programmer to do this?
Thanks
If you go to the YouTube video’s page, it’s in the description. It is from this site: https://shop.rewa.tech/
aliexpress is the one option or union something i forgot
Thank you for the link!
Does this also work on iPhone 8 Plus?
Does the iPad Pros have the same issue? If so, will this work? I assume it’s just an EDP protocol.
How I can activate true tone on my X's device, actually I replaced the screen before 3 months
Is there any way to do it by mobile to mobile or with any network?
I really suggest trying to reach out to the company beforehand. I've been trying to get some help with this device for 2 weeks and they're not responsive. I keep getting an “IIC chip not recognized!” error when trying to use the method without the original screen. Just suggesting to try reaching the company prior to committing. Seems like you'll largely be on your own after purchase.
Nice one, please how do I get the display extended models tools ???
I change my display and fix the original display but true tone is missing I updated my phone 15.4.1 but still true tone missing
If any possibility to fix the problem with out reopening my phone any software available
Should work most probably just with screen. Don't get your hopes high for the face id or touch id though. why would you be replacing the module if it can be read by this module? If the belt is broken then this module aint gonna read the data either, just saying.
Where can I buy the multi function programmer to reprogram the TrueTone?
Anyone had issue when reprogramming original iPhone XS screen damaged somehow touch ic? , touch is unresponsive on my XS but surprisingly it is working fine on iPhone X, I have tried to transfer data with MEGA-IDEA programmer from few different screens but no luck , touch only works on iPhone X but can’t use it on X as frame is different.
visit iphonesringtone.com
Really you have help alot in fixing true tone issue. Thanks Regards! iPhone Ringtone
Can u guys help to restore true tone on my iPhone without original screen
Hi, does anyone know if this will work with used OEM screens? Will it overwrite the previously written data on the screen? Thanks
blitzn - Yanıt
Depends on the aftermarket screen. Some can only be written once.
bearzac -
Yes I’ve done but still the True Tone is not showing
Yoanne Patrick Koudou - Yanıt
Doesn’t work without original screen on iOS 16. Anyone know if an update is coming to allow this?
bearzac - Yanıt
