Ana içeriğe geç
How To Restring a Yo-Yo
Neye ihtiyacın var
    1. How To Restring a Yo-Yo, String: adım 1, 1 resimden 1.
      • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
      FixBot'a Sor
      Yorum Ekle
    2. How To Restring a Yo-Yo: adım 2, 1 resimden 1.
      • Analyze the current state of the string.
      • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
      • If the string is damaged beyond repair, then get your new string ready.
      FixBot'a Sor
      Yorum Ekle
    3. How To Restring a Yo-Yo: adım 3, 1 resimden 1.
      • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
      • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
      FixBot'a Sor
      Yorum Ekle
    4. How To Restring a Yo-Yo: adım 4, 1 resimden 1.
      • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
      • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
      FixBot'a Sor
      Yorum Ekle
    5. How To Restring a Yo-Yo: adım 5, 1 resimden 1.
      • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
      FixBot'a Sor
      Yorum Ekle
    6. How To Restring a Yo-Yo: adım 6, 1 resimden 1.
      • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
      • This will ensure that the placement of the string is secure.
      FixBot'a Sor
      Yorum Ekle
    7. How To Restring a Yo-Yo: adım 7, 1 resimden 1.
      • Screw the halves back together firmly, making sure that they are aligned correctly.
      • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
      FixBot'a Sor
      Yorum Ekle
    8. How To Restring a Yo-Yo: adım 8, 1 resimden 1.
      • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
      FixBot'a Sor
      Yorum Ekle
Sonuç
After following these steps, you will have successfully restrung your Yo-Yo.
3 farklı kişi bu kılavuzu tamamladı.
1Rehber Yorum
nice tutorial
sdsdsds - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 17
Son 30 gün: 89
Her zaman: 6,221
