Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Mağaza
Giriş
Can iPhone 11 Pro possibly be turned into iPhone 11 Pro Max? It is actually theoretically possible. With pins of the two phones’ display connector and touch connector functioning almost the same, we can turn an iPhone 11 Pro into an iPhone 11 Pro Max by changing board ID resistors.
Videoya Genel Bakış
  1. iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro VS iPhone 11 Pro Max
    • iPhone 11 Pro comes with a 5.80-inch touchscreen display.
    • iPhone 11 Pro Max comes with a 6.50-inch touchscreen display.
  2. What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
    • What will happen when we connect the iPhone 11 Pro Max screen with the housing of iPhone 11 Pro directly?
  3. Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • Compare the motherboard of iPhone 11 Pro and that of iPhone 11 Pro Max. The component array of the two is almost the same. There is one more board ID resistor next to CPU on iPhone 11 Pro.
    • All we need to do is remove the extra board ID resistor.
  4. We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
    • We can see on the interface of 3uTools that the phone has entered DFU mode. And the phone has been turned into iPhone 11 Pro Max. We can write firmware of iPhone 11 Pro Max to the phone.
Phryne
10.421 İtibar
80 adet Kılavuz yazıldı
2 Yorum
Very impressive. Thanks a lot!
viona - Yanıt
hope it can help you somehow!
Phryne -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 39
Son 30 gün: 164
Her zaman: 1,788
