Ana içeriğe geç
Safely remove PC case stickers
Neye ihtiyacın var
  1. Safely remove PC case stickers, Remove the battery (Laptops only): adım 1, 2 resimden 1. Safely remove PC case stickers, Remove the battery (Laptops only): adım 1, 2 resimden 2.
    • The procedure to remove the battery is specific to every laptop.
    • Before removing the stickers, remove the battery.
  2. Safely remove PC case stickers, Warm up the adhesive: adım 2, 3 resimden 1. Safely remove PC case stickers, Warm up the adhesive: adım 2, 3 resimden 2. Safely remove PC case stickers, Warm up the adhesive: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    iFixit Opening Picks (Set of 6)
    Satın Al
    • 30-60 seconds of heat is sufficient.
    • If the sticker is thin, a guitar pick may help.
    • After removing the battery, warm up the palmrest with a hairdryer until it is warm to the touch.
    • Peel the stickers off.
  3. Safely remove PC case stickers, Clean the remaining glue: adım 3, 3 resimden 1. Safely remove PC case stickers, Clean the remaining glue: adım 3, 3 resimden 2. Safely remove PC case stickers, Clean the remaining glue: adım 3, 3 resimden 3.
    • While denatured alchol works, it may "strip" some rubber coatings and paint! Use good judgement!
    • After the sticker(s) have been removed, clean the residual glue with a small amount of gentle solvent.
    • Clean the solvent after a few seconds.
Bitiş Çizgisi
6 farklı kişi bu kılavuzu tamamladı.
Nick
88.851 İtibar
49 adet Kılavuz yazıldı
Ekip
Master Techs Master Techs üyesi
Community
322 Üyeler
2.528 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 39
Son 30 gün: 132
Her zaman: 15,705
