Giriş
Follow this guide to add a disc drive to your PlayStation 5 Pro. Be aware that you'll need a new console cover that will fit over the drive.
Adding a disc drive to your PS5 Pro allows you to play disc-based games, Blu-rays, or DVDs.
An internet connection is required to set up and pair your new disc drive.
Shut down your PlayStation and unplug all cables and accessories.
Remove any stands supporting your console and lay it down so the right side is facing up.
Firmly pull up the front edge of the larger, lower cover to release the clips.
Place the hooks on the drive's left edge into their cutouts on the frame and lay the drive onto your PlayStation.
Firmly press the right edge into place so the disc drive connector slides into its socket on the bottom right corner.
4 farklı kişi bu kılavuzu tamamladı.
