Ana içeriğe geç
How to Add a Hole to a Belt
Neye ihtiyacın var
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: adım 1, 1 resimden 1.
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: adım 2, 2 resimden 1. How to Add a Hole to a Belt: adım 2, 2 resimden 2.
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: adım 3, 1 resimden 1.
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: adım 4, 2 resimden 1. How to Add a Hole to a Belt: adım 4, 2 resimden 2.
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: adım 5, 2 resimden 1. How to Add a Hole to a Belt: adım 5, 2 resimden 2.
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: adım 6, 2 resimden 1. How to Add a Hole to a Belt: adım 6, 2 resimden 2.
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
Sonuç
After you complete the final step to your liking the fix is done.
Alexa Velazquez
133 İtibar
1 Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 11
Son 30 gün: 45
Her zaman: 1,370
