Ana içeriğe geç
How to Add an Extension to a Chain Bracelet
Neye ihtiyacın var
  1. How to Add an Extension to a Chain Bracelet, How to Add an Extension to a Chain Bracelet: adım 1, 2 resimden 1. How to Add an Extension to a Chain Bracelet, How to Add an Extension to a Chain Bracelet: adım 1, 2 resimden 2.
    • Unclasp the bracelet and lay it out flat.
  2. How to Add an Extension to a Chain Bracelet: adım 2, 3 resimden 1. How to Add an Extension to a Chain Bracelet: adım 2, 3 resimden 2. How to Add an Extension to a Chain Bracelet: adım 2, 3 resimden 3.
    • Locate the small opening on the last link of the bracelet.
    • Grip each side of the ring with a pair of pliers.
    • Slowly pull the link to expand the opening, with care not to snap it.
  3. How to Add an Extension to a Chain Bracelet: adım 3, 3 resimden 1. How to Add an Extension to a Chain Bracelet: adım 3, 3 resimden 2. How to Add an Extension to a Chain Bracelet: adım 3, 3 resimden 3.
    • Remove the end most portion of the bracelet.
    • Use pliers to close the last link that your previously opened.
  4. How to Add an Extension to a Chain Bracelet: adım 4, 3 resimden 1. How to Add an Extension to a Chain Bracelet: adım 4, 3 resimden 2. How to Add an Extension to a Chain Bracelet: adım 4, 3 resimden 3.
    • Find the piece that connects the clasp and the bracelet and locate the small opening in that piece.
    • Using 2 pliers, take the piece connecting the clasp and the bracelet and gently pull it apart to expand the opening.
  5. How to Add an Extension to a Chain Bracelet: adım 5, 3 resimden 1. How to Add an Extension to a Chain Bracelet: adım 5, 3 resimden 2. How to Add an Extension to a Chain Bracelet: adım 5, 3 resimden 3.
    • Remove the clasp.
    • Using one of the two pliers, close the link that was separated by slowly pushing the sides back into place.
  6. How to Add an Extension to a Chain Bracelet: adım 6, 3 resimden 1. How to Add an Extension to a Chain Bracelet: adım 6, 3 resimden 2. How to Add an Extension to a Chain Bracelet: adım 6, 3 resimden 3.
    • Lay out the bracelet flat and facing upright.
    • Reopen one side of the bracelet using the two pliers and attach the extender (on the side that did not have the clasp).
  7. How to Add an Extension to a Chain Bracelet: adım 7, 1 resimden 1.
    • Close the ends of the chain connector using the 2 pliers again.
  8. How to Add an Extension to a Chain Bracelet: adım 8, 2 resimden 1. How to Add an Extension to a Chain Bracelet: adım 8, 2 resimden 2.
    • Use the clasp side of the connector and connect the two ends of the bracelet.
Sonuç
Following these steps will be the more efficient way to add an extension to a bracelet. To detach the extension from the bracelet and return to its original state, follow these instructions in reverse order.
Neha Bagepalli
157 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 2-8, Andersen Winter 2024 UC Davis, Team 2-8, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S2G8
2 Üyeler
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 17
Her zaman: 214
