Ana içeriğe geç
How to Adjust Cantilever Bicycle Brakes
Neye ihtiyacın var
  1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: adım 1, 3 resimden 1. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: adım 1, 3 resimden 2. How to Adjust Cantilever Bicycle Brakes, How to Adjust Cantilever Bicycle Brakes: adım 1, 3 resimden 3.
    • Lift bicycle onto the rear wheel by holding the handlebars.
    • Roll the rear wheel forward while placing the handlebars on the ground so that the bike rests upside down.
  2. How to Adjust Cantilever Bicycle Brakes: adım 2, 2 resimden 1. How to Adjust Cantilever Bicycle Brakes: adım 2, 2 resimden 2.
    • Identify the brake that is rubbing against the bike rim by spinning each wheel while listening for contact.
    • Identify which brake pad is making contact (left or right).
  3. How to Adjust Cantilever Bicycle Brakes: adım 3, 3 resimden 1. How to Adjust Cantilever Bicycle Brakes: adım 3, 3 resimden 2. How to Adjust Cantilever Bicycle Brakes: adım 3, 3 resimden 3.
    • Loosen the 6mm hex screw that is holding the noisy brake to the frame.
    • Make sure not to remove the bolt completely.
  4. How to Adjust Cantilever Bicycle Brakes: adım 4, 1 resimden 1.
    • Shift the brake so that the pad no longer makes contact with the rim.
  5. How to Adjust Cantilever Bicycle Brakes: adım 5, 2 resimden 1. How to Adjust Cantilever Bicycle Brakes: adım 5, 2 resimden 2.
    • Rotate the bicycle tire to ensure the brake is no longer rubbing against the rim.
    • Keep your fingers free of the spokes while the wheel is spinning!
  6. How to Adjust Cantilever Bicycle Brakes: adım 6, 2 resimden 1. How to Adjust Cantilever Bicycle Brakes: adım 6, 2 resimden 2.
    • Hold the brake in the new position where it no longer rubs.
    • Use the 6 mm hex key to tighten the brake bolt back on.
  7. How to Adjust Cantilever Bicycle Brakes: adım 7, 2 resimden 1. How to Adjust Cantilever Bicycle Brakes: adım 7, 2 resimden 2.
    • Rotate the wheel again to ensure the brake did not change positions while you were tightening it.
  8. How to Adjust Cantilever Bicycle Brakes: adım 8, 1 resimden 1.
    • Flip the bike back onto its wheels.
Sonuç
Go ride your bike!
Bir başkası bu kılavuzu tamamladı.
Devaughantee
194 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 955
