Ana içeriğe geç
How to Adjust a Buttonhole Size
Neye ihtiyacın var
  1. How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: adım 1, 3 resimden 1. How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: adım 1, 3 resimden 2. How to Adjust a Buttonhole Size, How to Adjust a Buttonhole Size: adım 1, 3 resimden 3.
    • Steps 1-3 demonstrate how to shorten a buttonhole when the button will not stay buttoned or needs to be replaced with a smaller button.
    • Using the ruler, measure the button you intend to use. Add 1/8” to this measurement for ease of buttoning.
  2. How to Adjust a Buttonhole Size: adım 2, 1 resimden 1.
    • Measure down from the top of the existing buttonhole to the length of your Step 1 measurement.
    • Make a small sewing chalk mark or insert a straight pin to mark how long your adjusted buttonhole should be.
  3. How to Adjust a Buttonhole Size: adım 3, 3 resimden 1. How to Adjust a Buttonhole Size: adım 3, 3 resimden 2. How to Adjust a Buttonhole Size: adım 3, 3 resimden 3.
    • Use either a sewing machine or needle and thread for this step.
    • Match the stitch width of the existing bar tack, and sew a new bar tack at the location of your chalk mark.
    • A bar tack is several long, narrowly spaced stitches that form the top of a T between shorter perpendicular stitches.
    • Check to make sure your button fits your adjusted buttonhole well.
  4. How to Adjust a Buttonhole Size: adım 4, 2 resimden 1. How to Adjust a Buttonhole Size: adım 4, 2 resimden 2.
    • Steps 4-8 demonstrate how to lengthen a buttonhole if it is too tight for your button or if you want to sew on larger buttons.
  5. How to Adjust a Buttonhole Size: adım 5, 3 resimden 1. How to Adjust a Buttonhole Size: adım 5, 3 resimden 2. How to Adjust a Buttonhole Size: adım 5, 3 resimden 3.
    • With the ruler, measure down from the top of the existing buttonhole to the length of your Step 4 measurement.
    • Make a small sewing chalk mark or insert a straight pin on the fabric at this place.
  6. How to Adjust a Buttonhole Size: adım 6, 2 resimden 1. How to Adjust a Buttonhole Size: adım 6, 2 resimden 2.
    • Starting on the right of the existing buttonhole, stitch to your chalk mark or pin, matching the width of the original stitching.
    • Stitch a new bar tack.
    • Stitch back on your left to just past the original bar tack.
    • Tie off or backstitch your thread.
  7. How to Adjust a Buttonhole Size: adım 7, 1 resimden 1.
    • Using the point of your scissors, cut through the original bar tack and between your new side stitching until you have reached the new bar tack.
    • Do not cut through your new bar tack.
  8. How to Adjust a Buttonhole Size: adım 8, 2 resimden 1. How to Adjust a Buttonhole Size: adım 8, 2 resimden 2.
    • If using the existing button, you may have to cut it off and move it slightly to be centered in the larger buttonhole and resew it on.
    • Very near the place where your button was originally sewn on, center your button in your adjusted buttonhole. Using chalk or a pin, mark this location.
    • Sew your button on.
    • Check to make sure it fits through your adjusted buttonhole well.
Sonuç
A sewing machine with a buttonhole presser foot is ideal, but this project can be completed with needle and thread.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 35
Son 30 gün: 184
Her zaman: 4,190
