Ana içeriğe geç
How to Adjust a Piano Key Slip
Neye ihtiyacın var
  1. How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: adım 1, 3 resimden 1. How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: adım 1, 3 resimden 2. How to Adjust a Piano Key Slip, How to Adjust a Piano Key Slip: adım 1, 3 resimden 3.
    • Locate the keys that hold your key slip to the piano.
    • They are typically underneath the piano keyboard and there will be between two and four screws.
    • Check to see what kind of screw it is. In the case of this piano, it is a flathead screw; however there could be a variety of screws.
  2. How to Adjust a Piano Key Slip: adım 2, 3 resimden 1. How to Adjust a Piano Key Slip: adım 2, 3 resimden 2. How to Adjust a Piano Key Slip: adım 2, 3 resimden 3.
    • Remove all the screws from the piano and set them aside.
  3. How to Adjust a Piano Key Slip: adım 3, 2 resimden 1. How to Adjust a Piano Key Slip: adım 3, 2 resimden 2.
    • Gently remove your key slip using your hands.
    • The key slip is the piece of wood that sits in front of the keys.
  4. How to Adjust a Piano Key Slip: adım 4, 3 resimden 1. How to Adjust a Piano Key Slip: adım 4, 3 resimden 2. How to Adjust a Piano Key Slip: adım 4, 3 resimden 3.
    • Check for debris under the keys.
    • You can vacuum out dust or remove pieces of paper and other objects that have fallen behind the key slip or through the keys.
  5. How to Adjust a Piano Key Slip: adım 5, 3 resimden 1. How to Adjust a Piano Key Slip: adım 5, 3 resimden 2. How to Adjust a Piano Key Slip: adım 5, 3 resimden 3.
    • Replace your key slip, ensuring that it sits evenly between the two ends of the piano.
  6. How to Adjust a Piano Key Slip: adım 6, 3 resimden 1. How to Adjust a Piano Key Slip: adım 6, 3 resimden 2. How to Adjust a Piano Key Slip: adım 6, 3 resimden 3.
    • Re-screw the key slip onto the piano.
    • Don't tighten the screws all the way down at first. Screw each one in a little bit to make it doesn't become uneven.
    • Go back and tighten the screws to your desired tightness.
    • Check the keys to make sure that the they are no longer sticking, and that the key slip is not too tight.
  7. How to Adjust a Piano Key Slip: adım 7, 3 resimden 1. How to Adjust a Piano Key Slip: adım 7, 3 resimden 2. How to Adjust a Piano Key Slip: adım 7, 3 resimden 3.
    • Check each key to make sure they are no longer sticking.
    • If you were successful, no keys will stick and your key slip will be properly placed!
Sonuç
Congratulations! Your keys are no longer sticky and if your key slip slips out of place again you now know how to fix it!
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 35
Her zaman: 2,169
