Ana içeriğe geç
How to Adjust a Violin Bow
  1. How to Adjust a Violin Bow, How to Adjust a Violin Bow: adım 1, 2 resimden 1. How to Adjust a Violin Bow, How to Adjust a Violin Bow: adım 1, 2 resimden 2.
    • Identify the adjusting screw at the butt end of the bow.
  2. How to Adjust a Violin Bow: adım 2, 1 resimden 1.
    • Carefully unscrew the adjusting screw .
  3. How to Adjust a Violin Bow: adım 3, 1 resimden 1.
    • Once you fully unscrew the adjusting screw, carefully remove both the frog and the adjusting screw from the bow.
  4. How to Adjust a Violin Bow: adım 4, 1 resimden 1.
    • While not allowing the hair to become tangled, insert a small part of the adjusting screw so that only a small portion of the tip is seen. You do not need to screw the adjusting screw into the eyelet.
  5. How to Adjust a Violin Bow: adım 5, 2 resimden 1. How to Adjust a Violin Bow: adım 5, 2 resimden 2.
    • Carefully move the adjusting screw to tighten the eyehole, moving in a clockwise direction. To loosen, move the eyehole in a counter-clockwise direction.
    • Do not screw more than 180 degrees during adjustment to ensure you do not damage the bow.
  6. How to Adjust a Violin Bow: adım 6, 1 resimden 1.
    • Once you have either tightened or loosened the eyehole by 180 degrees, remove the adjusting screw from the eyehole.
    • Once you have finished, make sure the hairs are not tangled and have not become damaged during the adjusting process.
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 9
Her zaman: 1,002
