Ana içeriğe geç
How to Align the Envelope Modulator on a Dunlop Crybaby Pedal
Neye ihtiyacın var
  1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal, How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 1, 3 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal, How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 1, 3 resimden 2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal, How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 1, 3 resimden 3.
    • Remove all four of the 5 mm screws from the bottom panel of the pedal using a Phillips #1 screwdriver.
  2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 2, 3 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 2, 3 resimden 2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 2, 3 resimden 3.
    • Twist away the bottom panel to expose the inner components.
    • Do not remove the bottom panel entirely.
    • Be sure not to pull too hard on the wires when twisting the bottom panel.
  3. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 3, 3 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 3, 3 resimden 2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 3, 3 resimden 3.
    • Locate and pick up the envelope modulator.
    • It will have a cylindrical gear attached to it.
  4. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 4, 2 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 4, 2 resimden 2.
    • Move the nut and washer to the upper section of the thread.
  5. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 5, 3 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 5, 3 resimden 2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 5, 3 resimden 3.
    • Place the base of the modulator between the two rods of metal that will hold it in place and align the straight spur gear with the cylindrical gear.
    • You will see the teeth of the gears interlocked.
  6. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 6, 3 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 6, 3 resimden 2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 6, 3 resimden 3.
    • Use a 1/2" wrench or metal pliers to tighten in the nut and the washer to hold the modulator in place.
    • You can test to see if it is tight enough by rocking the pedal back and forth as if you were playing, and seeing the cylindrical gear rotate.
  7. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 7, 3 resimden 1. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 7, 3 resimden 2. How to Align the Envelope Modulator on a Dunlop Crybaby Pedal: adım 7, 3 resimden 3.
    • Twist back the bottom panel.
    • Use the Phillips #1 screwdriver to screw back in the four 5 mm screws.
Sonuç
Now that the envelope modulator is realigned, you are now ready to play it once again!
Collin
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 15
Her zaman: 99
