Ana içeriğe geç
How to Alter a Lengha Blouse
Neye ihtiyacın var
  1. How to Alter a Lengha Blouse, How to Alter a Lengha Blouse: adım 1, 1 resimden 1.
    • Take the measuring tape and wrap it around under your bust. Take note of this measurement.
    • Divide the measurement by two and take note. This will be the measurement used to tighten the blouse in step 4.
  2. How to Alter a Lengha Blouse: adım 2, 2 resimden 1. How to Alter a Lengha Blouse: adım 2, 2 resimden 2.
    • Take the blouse, and flip it inside out.
    • The inside of blouse must be facing outward.
  3. How to Alter a Lengha Blouse: adım 3, 1 resimden 1.
    • Lay the blouse with the front facing upward on a flat surface.
  4. How to Alter a Lengha Blouse: adım 4, 1 resimden 1.
    • Stretch the measuring tape across the bottom of the blouse and use the measurement from step one to evenly measure how much to take it in on both sides.
  5. How to Alter a Lengha Blouse: adım 5, 2 resimden 1. How to Alter a Lengha Blouse: adım 5, 2 resimden 2.
    • Use fabric chalk to mark where you will be sewing on each side of the blouse.
  6. How to Alter a Lengha Blouse: adım 6, 1 resimden 1.
    • Select a thread that matches the blouse preferably, otherwise any color is fine.
    • For clarity we will be using a yellow thread.
  7. How to Alter a Lengha Blouse: adım 7, 2 resimden 1. How to Alter a Lengha Blouse: adım 7, 2 resimden 2.
    • Take the thread and insert it into the needles hole and pull approximately 30cm of the thread through.
    • It is fine if there is extra thread remaining after the stitching.
  8. How to Alter a Lengha Blouse: adım 8, 1 resimden 1.
    • Put the two sides of the thread together to make a single thicker thread.
    • Tie the end and cut the remaining thread, leaving you with a long line of thread for stitching.
  9. How to Alter a Lengha Blouse: adım 9, 1 resimden 1.
    • Position the needle pointing upward at the bottom of the blouse, where it is marked with chalk to begin stitching.
  10. How to Alter a Lengha Blouse: adım 10, 1 resimden 1.
    • Push needle upward through both pieces of the cloth.
    • Pull through the entire thread until the knotted end of the thread stops the thread from being pulled any further.
  11. How to Alter a Lengha Blouse: adım 11, 2 resimden 1. How to Alter a Lengha Blouse: adım 11, 2 resimden 2.
    • Measure a short interval and push the needle down into the blouse again.
  12. How to Alter a Lengha Blouse: adım 12, 1 resimden 1.
    • Continue steps 9-11 until you reach the top of the cloth. This will create a running stitch.
  13. How to Alter a Lengha Blouse: adım 13, 1 resimden 1.
    • Tie a knot at the end of the stitch.
    • Make sure it is close to the blouse. This photo demonstrates tying a knot away from the blouse.
  14. How to Alter a Lengha Blouse: adım 14, 1 resimden 1.
    • Cut the excess thread at the top and bottom of the garment.
  15. How to Alter a Lengha Blouse: adım 15, 1 resimden 1.
    • Repeat Steps 9-14 for the other side of the blouse.
    • Normally one side of the blouse will have a zipper. In that case it is not necessary to stitch the entire way through. Rather only stitch the part of the blouse that is already closed up.
    • In this image, the zipper only opens until the visible point, therefore stitch above that area.
  16. How to Alter a Lengha Blouse: adım 16, 1 resimden 1.
    • Flip the blouse right side out, and now you have a complete fitted Lengha blouse.
Sonuç
Try the top on and check the fitting. If it seems too tight or loose, then you may have taken the wrong measurements. You may need to cut the stitches and try again. The fitting should ideally not be skin tight but rather allow a bit of room to breath since it is commonly a non-stretch material. Once you are done, you have now altered the blouse to your size and it is ready to be worn.
aarushic
253 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 32
Son 30 gün: 167
Her zaman: 2,708
