Ana içeriğe geç
How to Apply Flash Unit Adhesives in Your Google Pixel 8a
Neye ihtiyacın var
  1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: adım 1, 3 resimden 1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: adım 1, 3 resimden 2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the logic board cover adhesive: adım 1, 3 resimden 3.
    • Use tweezers to remove the conductive tape adhesive from the top right corner of the motherboard cover.
    • Use the flat end of a spudger to scrape up any remaining bits of adhesive.
    • Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the adhesive residue and wipe it away with a microfiber cloth.
  2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 2, 3 resimden 1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 2, 3 resimden 2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 2, 3 resimden 3.
    • Remove the conductive tape adhesive from its larger clear backing and put it into place with the tab on the right.
    • Use the flat end of a spudger to press down and secure the conductive tape.
    • Remove the remaining liner.
  3. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: adım 3, 2 resimden 1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a, Apply the flash unit adhesive: adım 3, 2 resimden 2.
    • Check the condition of the adhesive on the bottom of the flash unit.
    • If the adhesive is undamaged and still sticky, you can skip the rest of this guide and return to your original repair guide.
    • If the adhesive is damaged or no longer sticky, follow the next three steps to replace it.
  4. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 4, 3 resimden 1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 4, 3 resimden 2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 4, 3 resimden 3.
    • During the remaining steps, be very careful not to strain or tear the delicate flash unit cable.
    • Use a spudger and tweezers to carefully scrape up and remove the old adhesive from the bottom of the flash unit.
  5. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 5, 3 resimden 1. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 5, 3 resimden 2. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 5, 3 resimden 3.
    • Remove the flash unit adhesive from its larger, clear liner and put it into place on the bottom of the flash unit.
    • Use the flat end of a spudger to press down and secure the adhesive.
  6. How to Apply Flash Unit Adhesives in Your Google Pixel 8a: adım 6, 1 resimden 1.
    • Firmly press the flash unit into place on the logic board cover to secure it with the adhesive.
    • Return to your original guide and continue with reassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Spencer Day
154.631 İtibar
1.033 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.752 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 536
