Ana içeriğe geç
How to Apply New Screen Adhesive in Your Google Pixel 8 Pro
Neye ihtiyacın var
  1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: adım 1, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: adım 1, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive from the frame: adım 1, 3 resimden 3.
    • In order for the new adhesive to properly seal, you must remove all the old screen adhesive and its residue.
    • Be very careful not to damage any of the spring contacts around the perimeter of your phone during the next two steps.
    • Use the flat end of a spudger to scrape up and remove all the old screen adhesive from the perimeter of the frame.
    • If you're having trouble, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to the adhesive and scrape it up.
  2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive residue: adım 2, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive residue: adım 2, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive residue: adım 2, 3 resimden 3.
    Bu adımda kullanılan alet:
    Microfiber Cleaning Cloths
    $3.99
    • Once you've removed all the old adhesive, apply a few drops of highly-concentrated (greater than 90%) isopropyl alcohol to any residue left on the frame and wipe it away with a microfiber or lint-free cloth.
    • If you're having trouble, wrap the microfiber cloth around a spudger and use it to scrape the frame.
  3. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive from the screen: adım 3, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive from the screen: adım 3, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the old adhesive from the screen: adım 3, 3 resimden 3.
    • If you're installing a new screen, skip this step.
    • Repeat the cleaning procedure to remove all the old adhesive and its residue from the perimeter of the screen.
  4. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Align the adhesive: adım 4, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Align the adhesive: adım 4, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Align the adhesive: adım 4, 3 resimden 3.
    • Before applying the new adhesive, it's helpful to see how it will be oriented on your phone.
    • Hold the adhesive sheet so the clear liner is on the bottom and place it over your phone to find the proper alignment.
    • The blue liner has a large cutout for the cable on the left side of the phone and cutouts along the bottom for the spring contacts.
  5. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the clear liner: adım 5, 1 resimden 1.
    • Remove the larger clear liner from the back of the sheet to expose the adhesive.
  6. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Place the adhesive: adım 6, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Place the adhesive: adım 6, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Place the adhesive: adım 6, 3 resimden 3.
    • Be very careful during this step! Once the adhesive sticks to the frame, you won't be able to reposition it. You'll have to start over with new adhesive if it gets applied incorrectly.
    • Gently place the bottom edge of the adhesive onto the frame. Use the frame's lip to help position the sheet.
    • Press down gently to secure the bottom corners and carefully lay the rest of the adhesive onto the frame.
  7. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Secure the adhesive: adım 7, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Secure the adhesive: adım 7, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Secure the adhesive: adım 7, 3 resimden 3.
    • The adhesive needs to be firmly secured to the frame before removing any liners. This prevents the adhesive from pulling up and misaligning in the next step.
    • Press down firmly and slide the flat end of a spudger around the entire perimeter of the frame to secure the adhesive.
    • Be very careful not to damage any of the spring contacts around the perimeter of your phone.
  8. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the larger blue liner: adım 8, 2 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the larger blue liner: adım 8, 2 resimden 2.
    • Use the pull tab near the top of the phone to gently peel up and remove the larger blue liner.
    • If any of the adhesive starts to peel up with the liner, gently lay it back on the frame and use the flat end of a spudger to secure it.
  9. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Reconnect the screen: adım 9, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Reconnect the screen: adım 9, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Reconnect the screen: adım 9, 3 resimden 3.
    • Reconnect the screen cable press connector.
    • Reinstall the screen cable cover.
  10. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the remaining blue liners: adım 10, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the remaining blue liners: adım 10, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Remove the remaining blue liners: adım 10, 3 resimden 3.
    • Use a small box or stack of books to prop up the screen.
    • Use the two pull tabs on the upper right edge of the phone to remove the remaining blue liners.
  11. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Position the front camera: adım 11, 2 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Position the front camera: adım 11, 2 resimden 2.
    • Before securing the screen, make sure the front facing camera is snug in its recess.
    • If you replaced your screen, check the front-facing camera hole and the sensor cutout on your replacement screen, and remove any remaining liners.
  12. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Secure the screen: adım 12, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Secure the screen: adım 12, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Secure the screen: adım 12, 3 resimden 3.
    • Firmly press the screen into place on the frame. You should feel the clips "pop" into place.
    • Press firmly around the perimeter or the screen to secure it with the new adhesive.
  13. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Strengthen the adhesive bond: adım 13, 3 resimden 1. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Strengthen the adhesive bond: adım 13, 3 resimden 2. How to Apply New Screen Adhesive in Your Google Pixel 8 Pro, Strengthen the adhesive bond: adım 13, 3 resimden 3.
    • This step shows how to further strengthen the bond of your new screen adhesive.
    • In order to get even pressure around the perimeter of the screen, you'll need to account for the rear camera bump by placing objects on the rear cover.
    • Lay your phone screen side down on a clean, flat surface.
    • Put tape around the perimeter of your phone to protect the rear cover.
    • Place coins or similarly thick objects around the perimeter of the back cover. Make sure they're as thick or thicker than the camera bump.
    • Place heavy objects such as books on your phone and leave them for 30 minutes or longer. Ideally, leave them stacked overnight.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Spencer Day
149.870 İtibar
995 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
23.640 adet Kılavuz yazıldı
2Kılavuz Yorumları
Hey, I recently removed a broken screen from a Google pixel 8 Pro. It was in two pieces and the frame came off along with the actual glass and the foil piece with the fingerprint sensor on it. I wanted to reuse that fingerprint sensor on a quality screen and basically clean up any excess glue and go from there. I did the install. I made sure the screen worked and all was good. When I did install the screen I used a very small piece of double-sided tape which must have been a little too thick to basically get the fingerprint sensor to stick. I didn't want to use glue or any type of material like that so I figured a thin layer of tape even if I had to remove it later. If it didn't work would work. I installed everything and the screen worked and believe it or not the fingerprint sensor worked. The only thing that didn't work was pulling down from the top was a problem. It wouldn't let me scroll down from the top and pull down the control menu with Wi-Fi, Bluetooth airplane mode, etc. That was the first problem.
Sean - Yanıt
My second problem was Dad at the bottom of the phone when the screen was off. I guess there's a piece called the buffer which is black in color and I believe controls the three buttons on the screen, the menu button, the back button, and the pull-up app button. What would happen is when I would press one of those buttons. It would do a long press and anywhere where I would press on the touch screen would do a long press. I did use a very small piece of double-sided tape. Like I said to put the fingerprint sensor to the screen which I figured was the problem. Joe, I've heard of people getting their phone and screen to work without the fingerprint sensor at all. So I figured take off the fingerprint sensor and go from there. But I found out the hard way that basically any small wrinkle or press or touching of the back of the screen will ruin It. And that's what happened. Just wondering how to go about using the original print sensor with the correct adhesive and the buffer for the three buttons. Any help?
Sean - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 34
Son 30 gün: 191
Her zaman: 4,089
