Neye ihtiyacın var
Make sure you have all the necessary parts to assemble the Soil Pro Mini.
Soil sensor
Battery
PCB
Wireless charger
Carefully fold the wireless charger just above the words "Wireless Charger".
The soil sensor, battery and wireless charger all need to be connected to the PCB.
Battery
Wireless charger
Soil sensor
The PCB and the wireless charger are inserted into the deep pocket of the soil sensor.
Assembly is easiest when the PCB is inserted at a slight angle.
Push the wireless charged in behind the PCB.
The PCB and wireless charger should be at the same height, but not inserted all the way.
The battery should be placed in front of the PCB. This is easiest when diagonally inserted.
The battery wires are in the upper righthand corner.
The components can now be pressed in all the way.
The PCB must be below the edge of the soil sensor. The wireless charger is allowed to stick out a little bit.
Put the assembled Soil Pro Mini back in the bag.
Place 20 assembled Soil Pro Minis back in the box.
Bir başkası bu kılavuzu tamamladı.
