Ana içeriğe geç
How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone
Neye ihtiyacın var
  1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the Device Help app: adım 1, 3 resimden 1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the Device Help app: adım 1, 3 resimden 2. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the Device Help app: adım 1, 3 resimden 3.
    • Swipe up from the bottom of the home screen and open the Device Help app.
    • If you don't see the app, use the search bar at the top of the screen.
  2. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Check your app version: adım 2, 2 resimden 1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Check your app version: adım 2, 2 resimden 2.
    • Click the three dots in the top right corner () and select About.
    • Check that your App Version is 12.6.1 or greater. If it's not, go to Google Play and update the Device Help app.
    • Return to the main page of the Device Help app.
  3. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the calibration tool: adım 3, 3 resimden 1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the calibration tool: adım 3, 3 resimden 2. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Open the calibration tool: adım 3, 3 resimden 3.
    • Click the three dots in the top right corner () again and select Calibrate sensor.
    • Click Continue twice in the bottom right corner, reading through the information on screen.
  4. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibration information: adım 4, 2 resimden 1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibration information: adım 4, 2 resimden 2.
    • Before starting the calibration, make sure your screen is clean and free of any dust or grime.
    • Check the three calibration blocks and ensure they're clean and undamaged.
    • You should have two blocks with indents, and a third block with small grooves on one side (which you should be able to feel). The grooved block may be smaller than the other two.
  5. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibrate your fingerprint sensor: adım 5, 3 resimden 1. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibrate your fingerprint sensor: adım 5, 3 resimden 2. How to Calibrate the In-Screen Optical Fingerprint Sensor on Your Motorola Phone, Calibrate your fingerprint sensor: adım 5, 3 resimden 3.
    • Click Start in the top left corner and follow the instructions on screen to complete the calibration.
    • During calibration, note the following:
    • Make sure the blocks are aligned with and covering the red square on your screen.
    • You only need to press gently on the blocks. Don't compress them.
    • During Step 3, make sure the grooves on the bottom of the block are oriented correctly, as described in the on-screen instructions.
Sonuç
Your optical fingerprint sensor is calibrated and ready for use.
If the calibration failed for any reason, repeat the calibration procedure.
2 farklı kişi bu kılavuzu tamamladı.
Spencer Day
61.610 İtibar
445 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
140 Üyeler
18.058 adet Kılavuz yazıldı
Bir Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 23
Son 7 gün: 113
Son 30 gün: 430
Her zaman: 5,785
