Ana içeriğe geç
How to Change Broken Buttons on your Lexus Key Fob
  1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: adım 1, 2 resimden 1. How to Change Broken Buttons on your Lexus Key Fob, Broken Buttons: adım 1, 2 resimden 2.
    • Place the key fob with the removable metal key facing towards you.
  2. How to Change Broken Buttons on your Lexus Key Fob: adım 2, 3 resimden 1. How to Change Broken Buttons on your Lexus Key Fob: adım 2, 3 resimden 2. How to Change Broken Buttons on your Lexus Key Fob: adım 2, 3 resimden 3.
    • With the button side facing you, pull the metal latch down towards you to pull out the key.
  3. How to Change Broken Buttons on your Lexus Key Fob: adım 3, 3 resimden 1. How to Change Broken Buttons on your Lexus Key Fob: adım 3, 3 resimden 2. How to Change Broken Buttons on your Lexus Key Fob: adım 3, 3 resimden 3.
    • With the exposed corner facing you, place the metal key into the slot.
    • Turn the key sideways to open the key fob.
    • You may feel like you're breaking the key fob, but be firm while twisting.
  4. How to Change Broken Buttons on your Lexus Key Fob: adım 4, 2 resimden 1. How to Change Broken Buttons on your Lexus Key Fob: adım 4, 2 resimden 2.
    • Remove the motherboard and battery to access the buttons.
  5. How to Change Broken Buttons on your Lexus Key Fob: adım 5, 3 resimden 1. How to Change Broken Buttons on your Lexus Key Fob: adım 5, 3 resimden 2. How to Change Broken Buttons on your Lexus Key Fob: adım 5, 3 resimden 3.
    • Rotate the front plate, the broken buttons should fall out with ease.
    • Replace the broken buttons as necessary.
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply firm pressure when snapping the front and back covers together.
7 farklı kişi bu kılavuzu tamamladı.
Michael Tan
587 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 30-3, Green Spring 2015 Cal Poly, Team 30-3, Green Spring 2015 üyesi
CPSU-GREEN-S15S30G3
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
useless guide
Davide - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 12
Son 30 gün: 41
Her zaman: 6,103
