Ana içeriğe geç
How to Change Mortise Lock and its Cylinder
Neye ihtiyacın var
  1. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: adım 1, 3 resimden 1. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: adım 1, 3 resimden 2. How to Change Mortise Lock and its Cylinder, Mortise Lock and Cylinder: adım 1, 3 resimden 3.
    • Determine the position of the screws on both door handles and the front plate.
  2. How to Change Mortise Lock and its Cylinder: adım 2, 2 resimden 1. How to Change Mortise Lock and its Cylinder: adım 2, 2 resimden 2.
    • Use a flathead screwdriver to remove the eight 6 mm screws on both handles.
  3. How to Change Mortise Lock and its Cylinder: adım 3, 3 resimden 1. How to Change Mortise Lock and its Cylinder: adım 3, 3 resimden 2. How to Change Mortise Lock and its Cylinder: adım 3, 3 resimden 3.
    • Pull out the door handles on both sides of the door.
  4. How to Change Mortise Lock and its Cylinder: adım 4, 3 resimden 1. How to Change Mortise Lock and its Cylinder: adım 4, 3 resimden 2. How to Change Mortise Lock and its Cylinder: adım 4, 3 resimden 3.
    • Pull out the spindle (the rectangular piece of metal) from the door.
  5. How to Change Mortise Lock and its Cylinder: adım 5, 3 resimden 1. How to Change Mortise Lock and its Cylinder: adım 5, 3 resimden 2. How to Change Mortise Lock and its Cylinder: adım 5, 3 resimden 3.
    • Loosen the two 6 mm flathead screws at the top and bottom of the lock using a flathead screwdriver.
    • Remove the third 6 mm Phillips screw in the middle using a Phillips #1 screwdriver.
  6. How to Change Mortise Lock and its Cylinder: adım 6, 2 resimden 1. How to Change Mortise Lock and its Cylinder: adım 6, 2 resimden 2.
    • Pull the lock cylinder out to either side of the door.
  7. How to Change Mortise Lock and its Cylinder: adım 7, 3 resimden 1. How to Change Mortise Lock and its Cylinder: adım 7, 3 resimden 2. How to Change Mortise Lock and its Cylinder: adım 7, 3 resimden 3.
    • Grasp the mortise lock on either side and pull it out from the edge of the door.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 85
Her zaman: 1,848
