Ana içeriğe geç
How to Change Strings on a Ukulele
Neye ihtiyacın var
  1. How to Change Strings on a Ukulele, String: adım 1, 1 resimden 1.
    • Start by loosening the string you are trying to replace by twisting the pegs.
    • The G and C tuning pegs turn up to tighten and down to loosen while the E and A tuning pegs turn down to tighten and up to loosen.
  2. How to Change Strings on a Ukulele: adım 2, 1 resimden 1.
    • Next, grab the new string you are using to replace.
    • The packaging will inform you of which string replaces which note—some are different than others so pay attention!
  3. How to Change Strings on a Ukulele: adım 3, 1 resimden 1.
    • Feed the string through the tie block.
    • Remember to leave slack.
  4. How to Change Strings on a Ukulele: adım 4, 1 resimden 1.
    • Wrap the string over the tie block and back underneath itself.
  5. How to Change Strings on a Ukulele: adım 5, 2 resimden 1. How to Change Strings on a Ukulele: adım 5, 2 resimden 2.
    • Recross the string over itself again, looping it two or three more times.
  6. How to Change Strings on a Ukulele: adım 6, 1 resimden 1.
    • Pinch the string and pull tightly.
  7. How to Change Strings on a Ukulele: adım 7, 1 resimden 1.
    • Now, fasten the string back to the headstock. To do this, feed the string through the hole in the turning peg.
  8. How to Change Strings on a Ukulele: adım 8, 1 resimden 1.
    • Twist again to tighten and cut off extra string once complete.
Bitiş Çizgisi
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 899
