Ana içeriğe geç
How to Change Ukulele Strings For Left Handed Players
Neye ihtiyacın var
  1. How to Change Ukulele Strings For Left Handed Players, Ukulele Strings: adım 1, 3 resimden 1. How to Change Ukulele Strings For Left Handed Players, Ukulele Strings: adım 1, 3 resimden 2. How to Change Ukulele Strings For Left Handed Players, Ukulele Strings: adım 1, 3 resimden 3.
    • Unwind and clip the strings.
    • Remove the strings.
  2. How to Change Ukulele Strings For Left Handed Players: adım 2, 1 resimden 1.
    • The string order for a right handed ukulele is G-C-E-A, so we will put the strings in the reverse order for left handed people, A-E-C-G.
    • Feed the new strings through the holes in the bridge.
  3. How to Change Ukulele Strings For Left Handed Players: adım 3, 3 resimden 1. How to Change Ukulele Strings For Left Handed Players: adım 3, 3 resimden 2. How to Change Ukulele Strings For Left Handed Players: adım 3, 3 resimden 3.
    • Leave approximately 4 inches so you are able to tie the knot.
    • To tie the strings in a double knot, make a loose knot with the strings.
    • Feed the string back through the opening (as seen in the second image).
    • Once it is fed through the opening, pull it tight.
    • Tug on the string to ensure it is secure to the bridge.
  4. How to Change Ukulele Strings For Left Handed Players: adım 4, 3 resimden 1. How to Change Ukulele Strings For Left Handed Players: adım 4, 3 resimden 2. How to Change Ukulele Strings For Left Handed Players: adım 4, 3 resimden 3.
    • Once the strings are secured to the bridge, feed the strings through their corresponding tuning peg holes.
    • Wrap it around outwardly.
    • Feed it through the tuning peg again for a tighter fit.
  5. How to Change Ukulele Strings For Left Handed Players: adım 5, 1 resimden 1.
    • Ensure that the strings are wrapped around the tuning pegs from the inside out.
    • This image shows the direction the strings should be facing.
  6. How to Change Ukulele Strings For Left Handed Players: adım 6, 1 resimden 1.
    • Once the strings have been secured to their tuning pegs, wind each tuning peg in a counter-clockwise direction.
    • Wind each string roughly 15-20 times, or until the strings are tight and no longer loose.
    • Finally, tune your ukulele, and you're done!
Sonuç
Your ukulele is now playable for a left handed person!
Leah Garcia
133 İtibar
1 Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 26
Her zaman: 73
