Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Parts: (in order from left to right)
Short Screws
Latch mechanism with latch face
Long screws
Door knob with peg and screw holes (inside of the room)
Door knob with screw holes (outside of the room)
Face the inside of the knob, you should see two Phillips head screws on either side of the central knob.
You will see the latch face plate (the rectangular piece of metal) where the latch of the door knob is located.
Push the new latch mechanism with latch face plate into the door.
Insert the door knob that goes on the inside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
Align the door knob that goes on the outside of the room, aligning the peg and screw holes with the threaded cylinders of the latch mechanism.
Screw in both long screws on both sides of the door knob.
6 farklı kişi bu kılavuzu tamamladı.
