Ana içeriğe geç
How to Change to 12V Power Supply
Neye ihtiyacın var
      • Remove the modem so only the open-storm board remains. This is to prevent accidentally frying the modem.
      FixBot'a Sor
      Yorum Ekle
      • Remove the JP1 and JP2 jumpers
      FixBot'a Sor
      Yorum Ekle
      • Plug in the 12V power source
      FixBot'a Sor
      Yorum Ekle
      • Using a multimeter, touch the ground to any of the ground pinouts on the board and measure the JP1 and JP2 jumpers
      • You should see 12V on the middle and bottom pin of JP1 and 12V on the bottom pin of JP2. The top pin of JP2 should be ~ 3.6V
      FixBot'a Sor
      Yorum Ekle
      • If ~ 3.6 V measured on top JP2 jumper, then add jumper in new position.
      • JP2 powers the modem so it's very important that it is not supplied the higher voltage, otherwise the modem will fry.
      FixBot'a Sor
      Yorum Ekle
      • Plug in the 12V power supply again and see if the JP2 jumper measures ~ 3.7V
      FixBot'a Sor
      Yorum Ekle
      • Unplug the power source and plug in the modem.
      • Be vary careful to not skip a modem pin when plugging in and that it is oriented in the correct direction.
      • Power back on the board and wait to see a green light on the modem (indicating that it is properly powered and trying to connect to the internet).
      FixBot'a Sor
      Yorum Ekle
Sonuç
To revert back to 3.7V power, flip back the 2 jumpers to how they were at the start of the guide.
Meagan Tobias
154 İtibar
1 Kılavuz yazıldı
Ekip
Open-Storm Open-Storm üyesi
Community
14 Üyeler
46 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 282
