Neye ihtiyacın var
Pull the bonnet release handle located on the outboard side of the driver's side of the instrument panel. This will disengage the bonnet lock halfway
Push the under-bonnet release lever sideways with your finger. While pushing the lever, lift up the bonnet
Continue to lift up the bonnet until it is high enough to support with the prop rod
The component Intake air temperature sensor is located in the intake pipe just after the Air Filter.
Unplug the plug connection by pressing the release tab
Turn the knob in the multimeter to set the test to Ohms/Resistance
Connect the terminal 1 and 2 of the component Intake air temperature sensor to Multimeter positive and negative
The set value at ignition on and engine cold is 1.3KOhms
4 farklı kişi bu kılavuzu tamamladı.
