Ana içeriğe geç
How to Check Your iPhone's Battery Health
  1. How to Check Your iPhone's Battery Health, How to Check Your iPhone's Battery Health: adım 1, 1 resimden 1.
    • In order to proceed with this guide, your device must be running iOS 11.3 or higher.
    • Open the Settings app.
  2. How to Check Your iPhone's Battery Health: adım 2, 1 resimden 1.
    • Scroll down and select Battery.
  3. How to Check Your iPhone's Battery Health: adım 3, 1 resimden 1.
    • Select Battery Health.
  4. How to Check Your iPhone's Battery Health: adım 4, 1 resimden 1.
    • Maximum Capacity displays the total charge capacity of the battery compared to when the device was brand new.
    • Over many charge and discharge cycles, this number will gradually drop.
    • Your iPhone should continue to work fine, albeit with shortened battery life. Apple typically recommends replacing the battery once it degrades to 80% or lower.
  5. How to Check Your iPhone's Battery Health: adım 5, 3 resimden 1. How to Check Your iPhone's Battery Health: adım 5, 3 resimden 2. How to Check Your iPhone's Battery Health: adım 5, 3 resimden 3.
    • Peak Performance Capability tells you whether your battery can still supply sufficient power for the iPhone's most intense processing tasks. Normal peak performance is what you're aiming for.
    • If it says your iPhone has experienced an expected shutdown, that means your battery couldn't supply the needed power quickly enough, and the system shut down as a result.
    • Your iPhone will throttle its own performance—slowing itself down—in order to prevent further unexpected shutdowns. This can be disabled to manually enable peak performance.
    • Once you disable performance management, you cannot enable it again. It is automatically enabled after an unexpected shutdown.
    • Once your battery falls below a specific threshold (typically 80%), you will be notified that your battery's health is significantly degraded.
    • Follow this guide to replace your iPhone X battery, or click here for other iPhone models.
Sonuç
That's all folks!
28 farklı kişi bu kılavuzu tamamladı.
Josh M
913 İtibar
1 Kılavuz yazıldı
Ekip
iTech West Palm Beach iTech West Palm Beach üyesi
Business
5 Üyeler
7 adet Kılavuz yazıldı
4Kılavuz Yorumları
Battery Health no funciona con las baterías iFixit.
Cambié la batería de mi iPhone 6 por una batería iFixit y no se puede ver el porcentaje de batería máximo. Aparece “reparar“.
Con alguna aplicación de análisis de batería muestra 98%.
Jairo Ochoa - Yanıt
Under “Battery Health,” my iPhone SE says only “Service” and gives none of the information listed here.
Jeremy Nichols - Yanıt
Most likely your battery is below the recommended threshold and should be replaced.
If you replaced your battery, it may continue to say “Service”. I would recommend using a computer app like coconutBattery to check.
Josh M -
mine iphone 6 cannot watch battery health
gfght - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 7
Son 7 gün: 110
Son 30 gün: 243
Her zaman: 13,633
