Ana içeriğe geç
How to Check a Car's Tire Pressure
Neye ihtiyacın var
  1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: adım 1, 2 resimden 1. How to Check a Car's Tire Pressure, How to Check a Car's Tire Pressure: adım 1, 2 resimden 2.
    • Your car's tire pressure information is likely located inside the car door frame toward the bottom.
    • You can also look up this information in your vehicle's owner's manual.
    • Do not refer to the tire pressure information printed on the tire itself! This displays the maximum tire pressure allowed, rather than the recommended amount.
    FixBot'a Sor
    Yorum Ekle
  2. How to Check a Car's Tire Pressure: adım 2, 3 resimden 1. How to Check a Car's Tire Pressure: adım 2, 3 resimden 2. How to Check a Car's Tire Pressure: adım 2, 3 resimden 3.
    • Each tire has a valve stem located on the outer part of the wheel that sticks out.
    • Remove the cap by unscrewing it counter-clockwise and set it off to the side.
    • The cap is very small, so be sure to keep track of it!
    FixBot'a Sor
    Yorum Ekle
  3. How to Check a Car's Tire Pressure: adım 3, 2 resimden 1. How to Check a Car's Tire Pressure: adım 3, 2 resimden 2.
    • Place the stem of the tire pressure gauge onto the tire's valve stem and push on it with a decent amount of force.
    • You'll hear a brief hissing noise as the valve stem quickly opens and closes. If the noise continues, you likely aren't pressing down hard enough.
    • After a second or two, remove the tire pressure gauge. Again, you'll hear a brief hissing noise.
    FixBot'a Sor
    Yorum Ekle
  4. How to Check a Car's Tire Pressure: adım 4, 2 resimden 1. How to Check a Car's Tire Pressure: adım 4, 2 resimden 2.
    • Check the gauge to see what the tire pressure is. If it's low, add air to the tire until the gauge reads the proper tire pressure.
    • To reset the gauge to zero, press down on the gauge's bleeder valve.
    FixBot'a Sor
    Yorum Ekle
Bitiş Çizgisi
3 farklı kişi bu kılavuzu tamamladı.
Craig Lloyd
42.921 İtibar
82 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 23
Son 30 gün: 125
Her zaman: 4,100
