Ana içeriğe geç
How to Clean SteelSeries Apex Pro Gaming Keyboard
Neye ihtiyacın var
  1. How to Clean SteelSeries Apex Pro Gaming Keyboard, How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 1, 1 resimden 1.
    • Place the keyboard down on a flat surface and disconnect from any power source.
  2. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 2, 3 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 2, 3 resimden 2. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 2, 3 resimden 3.
    • Pour some isopropyl alcohol into a paper towel.
    • Use the same paper towel to clean the keyboard and the keyboard rest pad.
  3. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 3, 2 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 3, 2 resimden 2.
    • Use your index finger and thumb to remove each key cap starting from left to right.
    • Remove the smaller key caps first so the surrounding larger key caps can be removed easier.
    • Place each key cap that was removed from the keyboard on a flat surface in order from left to right.
  4. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 4, 2 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 4, 2 resimden 2.
    • Use a can of compressed air to remove all the dust from the keyboard.
  5. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 5, 2 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 5, 2 resimden 2.
    • Dip a cotton swab into the isopropyl alcohol bottle.
    • Use the cotton swab to clean tight spots on the keyboard.
  6. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 6, 2 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 6, 2 resimden 2.
    • Dip another cotton swab in the isopropyl alcohol.
    • Use the cotton swab to clean the inside and outside of every key switch.
  7. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 7, 3 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 7, 3 resimden 2. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 7, 3 resimden 3.
    • Use your index finger and thumb to place the keycaps on the keyboard, starting from the top to the bottom.
  8. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 8, 3 resimden 1. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 8, 3 resimden 2. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 8, 3 resimden 3.
    • Use the paper towel to clean the keyboard, keyboard rest bar, and the keyboard's cable.
  9. How to Clean SteelSeries Apex Pro Gaming Keyboard: adım 9, 1 resimden 1.
    • Make sure all keycaps are placed in the right place and functioning properly.
Sonuç
Congratulations, your SteelSeries Apex Pro keyboard is clean! Repeat these steps every once in a while as needed to keep your keyboard clean and extend the life of your keyboard.
Luis Espinosa
169 İtibar
1 Kılavuz yazıldı
Ekip
CSU Los Angeles, Team 8-1, Briggs Spring 2022 CSU Los Angeles, Team 8-1, Briggs Spring 2022 üyesi
CSULA-BRIGGS-S22S8G1
2 Üyeler
2 adet Kılavuz yazıldı
2 Yorum
Je pense qu'utiliser de l'acool isopropylique est une c...erie
Guynemer - Yanıt
Pourquoi ? Argumentes.
Parce que ça désinfecte, nettoie en profondeur les touches sans risque de voir les caractères s'effacer ? (sauf clavier leader price bien sûr)
Valurion -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 38
Son 30 gün: 181
Her zaman: 5,548
