Ana içeriğe geç
How to Clean The Exit Needle of the Keurig B60
Neye ihtiyacın var
  1. How to Clean The Exit Needle of the Keurig B60, How to Clean The Exit Needle of the Keurig B60: adım 1, 1 resimden 1.
    • Lift Handle to open Lid
  2. How to Clean The Exit Needle of the Keurig B60: adım 2, 3 resimden 1. How to Clean The Exit Needle of the Keurig B60: adım 2, 3 resimden 2. How to Clean The Exit Needle of the Keurig B60: adım 2, 3 resimden 3.
    • Remove K-Cup Pack Holder Assembly by pinching the left and right sides to release clamp. Wiggle slightly to remove
  3. How to Clean The Exit Needle of the Keurig B60: adım 3, 3 resimden 1. How to Clean The Exit Needle of the Keurig B60: adım 3, 3 resimden 2. How to Clean The Exit Needle of the Keurig B60: adım 3, 3 resimden 3.
    • Pull and snap apart the funnel from the K-Cup Pack Holder (If this is the first time separating the Pack Holder Assembly, more force may be required)
  4. How to Clean The Exit Needle of the Keurig B60: adım 4, 2 resimden 1. How to Clean The Exit Needle of the Keurig B60: adım 4, 2 resimden 2.
    • Insert a paperclip or other small, sharp object into the bottom of the K-Cup Pack Holder needle compartment to clear out any debris. If debris is too dry and compact, perform this step under running water to loosen the debris
    • Flip K-Cup Pack Holder and repeat
  5. How to Clean The Exit Needle of the Keurig B60: adım 5, 2 resimden 1. How to Clean The Exit Needle of the Keurig B60: adım 5, 2 resimden 2.
    • With the Lid still open, locate the Puncture Needle. Insert a paperclip or other small sharp object into the Puncture Needle Holes to remove any debris trapped inside
Sonuç
Once reassembled, run the brewer once or twice with just water to cleanse the system.
10 farklı kişi bu kılavuzu tamamladı.
Jake Wynn
830 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 1-7, Maness Spring 2016 Cal Poly, Team 1-7, Maness Spring 2016 üyesi
CPSU-MANESS-S16S1G7
5 Üyeler
2 Yorum
I used the needle but it fell into the area.  How do I get the needle out?
pspicuzza - Yanıt
The bottom needle is loose on small piece of plastic is this normal or broke?
confused40 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 81
Her zaman: 26,618
