Ana içeriğe geç
How to Clean Up Solder from Connections
Neye ihtiyacın var
  1. How to Clean Up Solder from Connections, How to Clean Up Solder from Connections: adım 1, 1 resimden 1.
    • The materials needed for this are a soldering iron, soldering paste and desoldering wire, also known as a wick.
  2. How to Clean Up Solder from Connections: adım 2, 1 resimden 1.
    • There are many types of soldering paste many of which are in a syringe like tube which makes it easy to get the paste in the exact spot it needs to be.
    • I personally use a plastic opening tool to scoop a little out and apply it gently on the spot I will be working on.
  3. How to Clean Up Solder from Connections: adım 3, 1 resimden 1.
    • The location I will be de-soldering is right above the SPK location in the photo.
  4. How to Clean Up Solder from Connections: adım 4, 2 resimden 1. How to Clean Up Solder from Connections: adım 4, 2 resimden 2.
    • Place the de-soldering wick on the solder joint and put the tip of the soldering iron on it so the wick can heat up and absorb the old solder.
    • Please remember that logic board components are very fragile and excessive heat can destroy these components.
    • Lift the wick and the soldering iron up from the logic board at the same time. Failure to do so can cause the leftover solder to harden and solder the wick to the logic board and you could easily pull a logic board pad off.
  5. How to Clean Up Solder from Connections: adım 5, 1 resimden 1.
    • What’s left over is clean points on the solder board, ready for fresh solder.
Bitiş Çizgisi
77 farklı kişi bu kılavuzu tamamladı.
Romin McGowan
3.744 İtibar
1 Kılavuz yazıldı
Bir Yorum
Well Explained
Muhamamd Asif - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 16
Son 7 gün: 85
Son 30 gün: 509
Her zaman: 17,739
