Ana içeriğe geç
How to Clean a Canon PowerShot SD780 IS Shutter Button
Neye ihtiyacın var
  1. How to Clean a Canon PowerShot SD780 IS Shutter Button, How to Clean a Canon PowerShot SD780 IS Shutter Button: adım 1, 1 resimden 1.
    • Before starting, make sure to turn off the camera and remove the battery.
  2. How to Clean a Canon PowerShot SD780 IS Shutter Button: adım 2, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the five outermost screws from the camera.
  3. How to Clean a Canon PowerShot SD780 IS Shutter Button: adım 3, 1 resimden 1.
    • Remove the front panel of the camera case to expose the top left ribbon cable. Pull the ribbon cable gently to disconnect it from the camera.
  4. How to Clean a Canon PowerShot SD780 IS Shutter Button: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver remove the single screw on the far left-hand side towards the bottom of the camera.
  5. How to Clean a Canon PowerShot SD780 IS Shutter Button: adım 5, 1 resimden 1.
    • Carefully pull the case apart to separate the 2 pieces.
    • The case will detach from the camera in two pieces.
  6. How to Clean a Canon PowerShot SD780 IS Shutter Button: adım 6, 1 resimden 1.
    • Remove the two screws on the metal plate of the camera case. This will give you access to the spring inside the metal plate for further cleaning.
    • Clean the inside of the camera with a cloth to remove dust and excess grime. This should unstick the shutter button and allow for full function.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Arlene Ale
455 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 27
Her zaman: 919
