Ana içeriğe geç
How to Clean a Danby Room Air Conditioner Filter
Neye ihtiyacın var
  1. How to Clean a Danby Room Air Conditioner Filter, How to Clean a Danby Room Air Conditioner Filter: adım 1, 1 resimden 1.
    • Start by removing the air filtration panel, commonly located on the right side of the air conditioner. Using the little handle, simply pull the filter out.
    FixBot'a Sor
    Yorum Ekle
  2. How to Clean a Danby Room Air Conditioner Filter: adım 2, 2 resimden 1. How to Clean a Danby Room Air Conditioner Filter: adım 2, 2 resimden 2.
    • Gently tap the air filtration panel against the side of a garbage can or disposal area, to get rid of any loose dirt.
    • Using water and a brush of any sort, gently brush away the stubborn dirt.
    FixBot'a Sor
    Yorum Ekle
  3. How to Clean a Danby Room Air Conditioner Filter: adım 3, 1 resimden 1.
    • Once you have completely removed the dirt, gently dry the filter with a paper towel or dry cloth.
    • Place the filter aside and let it thoroughly dry for 30 minutes to 1 hour.
    FixBot'a Sor
    Yorum Ekle
  4. How to Clean a Danby Room Air Conditioner Filter: adım 4, 1 resimden 1.
    • After setting aside the filter, use the Phillips #1 screwdriver to remove the two 12.7 mm front panel screws from the air conditioner.
    • Gently pull the front panel off the unit.
    FixBot'a Sor
    Yorum Ekle
  5. How to Clean a Danby Room Air Conditioner Filter: adım 5, 3 resimden 1. How to Clean a Danby Room Air Conditioner Filter: adım 5, 3 resimden 2. How to Clean a Danby Room Air Conditioner Filter: adım 5, 3 resimden 3.
    • Clean the front unit with water and a brush, entirely, front and back. Once you finished cleaning the unit, make sure that the wind flaps are properly inserted into their slot and not damaged or moved when cleaning them.
    • Dry the front unit along with the filter anywhere from 30 mins and 1 hour each.
    • As the filter and unit are drying, take a water spray and brush down any dirt that may be clogged in the front panel of the Air Conditioner, till it returns to its original color. Then let the panel dry for 15-30 minutes.
    FixBot'a Sor
    Yorum Ekle
  6. How to Clean a Danby Room Air Conditioner Filter: adım 6, 1 resimden 1.
    • Once all three pieces (the air filter, front unit, and front panel) are all completely dried, simply screw back the front unit, and then re-insert the air filter into the side.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To Reassemble the front unit. Simple screw back the front unit and reinsert the filteration
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 54
Son 30 gün: 239
Her zaman: 9,838
