Ana içeriğe geç
How to Clean a Flat Iron
Neye ihtiyacın var
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: adım 1, 1 resimden 1.
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: adım 2, 2 resimden 1. How to Clean a Flat Iron: adım 2, 2 resimden 2.
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: adım 3, 2 resimden 1. How to Clean a Flat Iron: adım 3, 2 resimden 2.
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: adım 5, 2 resimden 1. How to Clean a Flat Iron: adım 5, 2 resimden 2.
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: adım 6, 2 resimden 1. How to Clean a Flat Iron: adım 6, 2 resimden 2.
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: adım 7, 1 resimden 1.
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: adım 8, 1 resimden 1.
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: adım 9, 1 resimden 1.
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
Sonuç
Congratulations your flat iron is buildup free!
3 farklı kişi bu kılavuzu tamamladı.
Jacquelin
283 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-2, Green Winter 2015 Cal Poly, Team 12-2, Green Winter 2015 üyesi
CPSU-GREEN-W15S12G2
6 Üyeler
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 21
Son 30 gün: 45
Her zaman: 5,764
