Ana içeriğe geç
How to Clean a GE JCBS250DM2WW Glass Oven Door
Neye ihtiyacın var
  1. How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 1, 3 resimden 1. How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 1, 3 resimden 2. How to Clean a GE JCBS250DM2WW Glass Oven Door, How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 1, 3 resimden 3.
    • Disconnect the oven from the power supply.
    • To prevent injuries, ensure that the oven is empty and cool.
  2. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 2, 3 resimden 1. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 2, 3 resimden 2. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 2, 3 resimden 3.
    • Open the oven door.
    • Use the the 3/32" Allen wrench to remove the two 8mm x 2mm M2 hex screws.
    • When both screws are removed, the door will separate. Make sure to hold it so it doesn't fall.
  3. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 3, 3 resimden 1. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 3, 3 resimden 2. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 3, 3 resimden 3.
    • The first glass panel is located on the bottom part as shown in the image.
    • Dip the soft sponge in the soapy water and gently rub the glass until there is no grease or spots.
    • Use a clean cloth to wipe the glass off so there are no streaks.
  4. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 4, 3 resimden 1. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 4, 3 resimden 2. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 4, 3 resimden 3.
    • The second glass panel is located on the top.
    • Use the sponge to clean the glass with a soap solution and soft clean cloth to wipe the glass off.
  5. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 5, 3 resimden 1. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 5, 3 resimden 2. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 5, 3 resimden 3.
    • For any hard remaining stains, make a paste of baking powder and water.
    • Mix three table spoons of baking power and two table spoons of water.
    • Use the sponge to apply it on the hard stains and let it rest for two minutes.
    • Use a soft cloth to wipe off the paste from the glass.
  6. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 6, 3 resimden 1. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 6, 3 resimden 2. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 6, 3 resimden 3.
    • To reassemble the door, press bottom and top part of the door together.
    • Replace the hex screws using the 3/32" Allen wrench.
  7. How to Clean a GE JCBS250DM2WW Glass Oven Door: adım 7, 1 resimden 1.
    • The oven door glass is now clean.
    • Be careful when reconnecting the oven to power.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Flying Feather
145 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 498
