Ana içeriğe geç
How to Clean a Mainstays Coffee Maker Water Tube
Neye ihtiyacın var
  1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: adım 1, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: adım 1, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube, How to Clean a Mainstays Coffee Maker Water Tube: adım 1, 3 resimden 3.
    • Open the top of the coffee maker.
  2. How to Clean a Mainstays Coffee Maker Water Tube: adım 2, 2 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 2, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 6 mm screws surrounding the puncturing needle.
  3. How to Clean a Mainstays Coffee Maker Water Tube: adım 3, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 3, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 3, 3 resimden 3.
    • Press down on the brew chamber release button and remove the backing piece.
  4. How to Clean a Mainstays Coffee Maker Water Tube: adım 4, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 4, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 4, 3 resimden 3.
    • Disconnect the water tube from where it is connected to the needle.
  5. How to Clean a Mainstays Coffee Maker Water Tube: adım 5, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 5, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 5, 3 resimden 3.
    • Flip the coffee maker upside down.
  6. How to Clean a Mainstays Coffee Maker Water Tube: adım 6, 2 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 6, 2 resimden 2.
    • Use a Phillips screwdriver to remove the four 7 mm screws on the base of the coffee maker.
  7. How to Clean a Mainstays Coffee Maker Water Tube: adım 7, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 7, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 7, 3 resimden 3.
    • Remove the base.
  8. How to Clean a Mainstays Coffee Maker Water Tube: adım 8, 2 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 8, 2 resimden 2.
    • Use an 8" Phillips screwdriver to remove the five internal 14 mm screws from within the coffee maker.
    • Use an 8" Phillips screwdriver to remove the six internal 7 mm screws from within the coffee maker.
    • The second image shows the approximate placement of the screws; you may have to reach inside and move wires to locate and access all eleven screws.
  9. How to Clean a Mainstays Coffee Maker Water Tube: adım 9, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 9, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 9, 3 resimden 3.
    • Flip the coffee maker right-side up.
  10. How to Clean a Mainstays Coffee Maker Water Tube: adım 10, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 10, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 10, 3 resimden 3.
    • Pull the disconnected end of the water tube out of the top of the coffee maker.
  11. How to Clean a Mainstays Coffee Maker Water Tube: adım 11, 1 resimden 1.
    • Move the top of the coffee maker out of the way so that you can reach into the base.
    • You may wish to put something under the top to support it.
  12. How to Clean a Mainstays Coffee Maker Water Tube: adım 12, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 12, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 12, 3 resimden 3.
    • Identify where the water tube is connected at the other end.
    • Use pliers or your hand to disconnect it.
    • If you choose to use pliers, take caution not to puncture the tube.
  13. How to Clean a Mainstays Coffee Maker Water Tube: adım 13, 3 resimden 1. How to Clean a Mainstays Coffee Maker Water Tube: adım 13, 3 resimden 2. How to Clean a Mainstays Coffee Maker Water Tube: adım 13, 3 resimden 3.
    • Locate any blockages in the water tube and use your chosen tool (chenille stick, wooden dowel, toothpick, etc.) to push them out.
    • If the tube looks cloudy, use a chenille stick to break up the buildup.
  14. How to Clean a Mainstays Coffee Maker Water Tube: adım 14, 1 resimden 1.
    • Rinse any remaining debris out of the tube.
    • Depending on what tool you chose to use in the previous step, particles from said tool may need to be rinsed out as well.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lorelei Kriss
269 İtibar
1 Kılavuz yazıldı
Ekip
UC Davis, Team 4-9, Andersen Winter 2024 UC Davis, Team 4-9, Andersen Winter 2024 üyesi
UCD-ANDERSEN-W24S4G9
2 Üyeler
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 7
Son 30 gün: 82
Her zaman: 1,314
