Ana içeriğe geç
How to Clean a Martin Yale 1611 Folding Machine
Neye ihtiyacın var
  1. How to Clean a Martin Yale 1611 Folding Machine, How to Clean a Martin Yale 1611 Folding Machine: adım 1, 3 resimden 1. How to Clean a Martin Yale 1611 Folding Machine, How to Clean a Martin Yale 1611 Folding Machine: adım 1, 3 resimden 2. How to Clean a Martin Yale 1611 Folding Machine, How to Clean a Martin Yale 1611 Folding Machine: adım 1, 3 resimden 3.
    • Use a Phillips #00 screwdriver to remove both screws on the ends of the top cover.
    • Once the screws are removed, lift the cover upwards to remove.
  2. How to Clean a Martin Yale 1611 Folding Machine: adım 2, 1 resimden 1.
    • To remove the first fold table, tilt it upwards and pull it away from the machine to slide it out.
  3. How to Clean a Martin Yale 1611 Folding Machine: adım 3, 1 resimden 1.
    • To remove the second fold table, tilt it upwards and pull it away from the machine to slide it out.
  4. How to Clean a Martin Yale 1611 Folding Machine: adım 4, 1 resimden 1.
    • Apply your dish soap to a small dampened sponge.
    • Make sure not to over soak the sponge or add too much soap.
  5. How to Clean a Martin Yale 1611 Folding Machine: adım 5, 3 resimden 1. How to Clean a Martin Yale 1611 Folding Machine: adım 5, 3 resimden 2. How to Clean a Martin Yale 1611 Folding Machine: adım 5, 3 resimden 3.
    • Carefully rub the sponge along each roller.
    • Turn each roller as you clean it to ensure it is completely cleaned.
    • Any dark (black) residue present on the sponge indicates an ink build up, so continue cleaning until all residue is gone.
Sonuç
Before reassembling, make sure all of the rollers are dry (you may use a cotton cloth). To reassemble your device, follow steps 1-3 in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 16
Her zaman: 867
