Giriş
If you’re watching a favorite old movie on your VCR and the picture is extra blurry or cuts out entirely it could be your VCR’s read heads are dirty and need cleaning. If you don’t have a head cleaning tape this process will yield the same results and may get your VCR back to playing your favorite classic tapes or awkward home videos from yesteryear.
For this guide I will be showing how to do it on my Emerson VCR953. The disassembly may be different on your model, but the cleaning procedure should be the same on all VCR models.
Neye ihtiyacın var
Remove the two 1/2" long #2 Philips screws from the rear of the case
Once the top shell is off you should have access to the read head drum.
Read head drum
Wrap the alcohol soaked paper around the read head drum and hold it in place against the drum with your thumb.
With the paper pressed against the drum use your other hand to rotate the drum in either direction.
Do this until no more dirt is coming off the drum onto the paper. You may need to flip the paper around to allow it to catch more dirt.
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Thanks so easy when you are shown
Keeps ejecting tape or stops?
