Ana içeriğe geç
How to Clean and Sharpen your Wahl Hair Clippers
Neye ihtiyacın var
  1. How to Clean and Sharpen your Wahl Hair Clippers, How to Clean and Sharpen your Wahl Hair Clippers: adım 1, 1 resimden 1.
    • Take your Philips head screwdriver and loosen the set screws by turning them left. This will allow you to separate the blades from your clipper.
  2. How to Clean and Sharpen your Wahl Hair Clippers: adım 2, 1 resimden 1.
    • Take a fine hair brush and sweep it across the clipper base. This will remove any hair debris.
  3. How to Clean and Sharpen your Wahl Hair Clippers: adım 3, 1 resimden 1.
    • Fully immerse and soak your blade in 90% isopropyl alcohol to remove any rust that might be present. The blade should soak a minimum of 5 minutes.
  4. How to Clean and Sharpen your Wahl Hair Clippers: adım 4, 1 resimden 1.
    • Take a clean lint free towel and dry the blade. While drying rub the blade in all directions applying light pressure and this will remove residue and polish the blade.
  5. How to Clean and Sharpen your Wahl Hair Clippers: adım 5, 1 resimden 1.
    • Run your blade left and right in a horizontal direction across a Whetstone honing stone. First on the coarse side to sharpen the blade then on the finishing side to smooth out the blade.
  6. How to Clean and Sharpen your Wahl Hair Clippers: adım 6, 1 resimden 1.
    • Rinse the honing stone under water and rub the stone back and forth the same direction you used to sharpen your blade. This will clean your stone and remove any debris.
  7. How to Clean and Sharpen your Wahl Hair Clippers: adım 7, 1 resimden 1.
    • Place your blades back into position and insert your set screws into the proper holes. Take your Philips screwdriver and turn the screws to the right until you feel them completely tighten. Be careful to line up your blades correctly.
  8. How to Clean and Sharpen your Wahl Hair Clippers: adım 8, 1 resimden 1.
    • Apply oil to the base of your blades before first use. Blades should be oiled after every 3 or 4 uses.
  9. How to Clean and Sharpen your Wahl Hair Clippers: adım 9, 1 resimden 1.
    • Your clippers are ready for use. Plug them in to let them run for a few moments before your first use.
Sonuç
20 farklı kişi bu kılavuzu tamamladı.
Joseph Makar
789 İtibar
1 Kılavuz yazıldı
Ekip
8 Yorum
What kind of oil? wd40 ?
zoobee22 - Yanıt
No. WD40 is not a lube and won't last. WD = Water Displacer.
Use mineral oil from your drug store.
Joe -
Much more easily said than done. I am extremely mechanically orientated and have tried three times to sharpen them. They are almost useless (Wahl animal Pro Series) after only two cuts.
Barry Jameson - Yanıt
Barry, read my comment to the step 5 - you’ll find how to do it correct.
vladintool -
My shaver after popping the head off to clean stop cutting.what steps can I take to fix this problem?
mdearl54@yahoo.com - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 33
Son 7 gün: 341
Son 30 gün: 1,342
Her zaman: 131,800
